Question about Athearn HO RTR John Deere 650H Dozer
On a komatsu D20A-5 mini dozer there are three wires coming off of the alternator the big white one goes to the battery but where do the other two go one is white with a red stripe and the other is white with a green stripe
ERROR CODE DHH4KA FOR KOMATSU D155AX-5 DOZER
Are you sure that is the correct code, I found the lists and possible causes for the Komatsu equipment lines and that one is not listed.
May 23, 2016 | Cars & Trucks
Need repair manual for Komatsu D20A,P,S,Q-6, D21A,P,S,Q-6 Dozer Bulldoze
Komatsu D20PL,PLL,AG-7,D20P,PG-7A,D21A,S,AG,QG-7,D21PG-7A Dozer Bulldozer Service Repair Manual
https://sellfy.com/p/DNUZ
Nov 23, 2015 | Cars & Trucks
Need repair manual for Komatsu D21A-8, D21P-8 Dozer Bulldozer
contact a service dealer spares department for the manual or cd
bet your life it won't be cheap but is probably the only place you will get one
Need repair manual for Komatsu D31EX-21,D31PX-21,D37EX-21,D37PX-21,D39EX-21,D39PX-21 Dozer Bulldozer
Downlaod Komatsu D31EX-21,D31PX-21,D37EX-21,D37PX-21,D39EX-21,D39PX-21 Dozer Bulldozer Service Repair Manual
https://sellfy.com/p/fmBE
4 cylinder valve adjustment
if you cannot get an answer contact a komatsu service centre for the settings but generally .012"inlet and .014"exhaust will get you running
Jan 12, 2014 | Cars & Trucks
Battery light alternator
The Charge lamp comes on with the Alternator fails to keep battery charge going. (lots of way to fail, and ALT Is 100% good) it's a system. each part of it must be good, end to end.
so...
i put my voltmeter across battery, i start car, i see 13.3 to 15vdc, alt is good.
no? , i see now, 12.2v. ALt is dead, (i didnt say bad) and battery is sightly discharged, 12.6v is charged. (key off, rested voltage)
This 12v tells me the ALT is shut down. only why is the question.
how can any charge system fail,
bad battery tops the list here, they LOVE to fail.
1: belt slips.
2: belt missing
3: bad alt.
4: bad wires to ALT . (corrosion on any wire or lug)
5: fuses blown , any listed below.:
your alt is not an ECU controlled, alt ,its 100% self contained
did you ever remove the ALT and blow the 100 amp fuseable link
the first step of any alt pul, is the pull the NEG, battery lug or BOOM.
im logged in to alldata.com so can you.
and what do i see.
a 5 wire ALT. one is the frame ground, so it must not be rusty or..... it fails. frame to engine block. no rust here.
wire L , yellow.goes to dash LEDs (alt failure idiot lamps) (this works)
wire. S white goes to ALT 5a fuse, is it blown?
wire :B B/G color, goes to the 100 amp link fuse. (blown>?)
wire IG Red-white, goes to a fuse marked 10A gauge.
i think the IG wire is the voltage sense wire.
no sense, no charge. I think the whole I/P dash cluster goes dead when this fuse blows.
The S wire is the boot strap voltage sense, it wakes up the regulator .
if open , the reg stays asleep, as does ALT.
Alternators can not self start, the regulator has boot strap device
that cures that. called self excitation. so this wire is critical.
All wires except the L wire is critical. in this case.
the B wire is the big wire, it charges the battery . 50amps or more..
any of the 5 paths open , kills the ALT dead.
The REG inside the ALT can also shut it down.
eg: battery bad, with huge cell resistances. total.
eg: overvoltge for any reasons. including attempts top run car with no battery, (dont ask)
eg: over current (battery cells 1 to 6 shorted) or 25 KC lamps added.
eg: over temperature shut down.
that is about it.
Dec 31, 2013 | 2003 Toyota Matrix
How much is a secondhand d31p komatsu bull-dozer manifold 1983 model
I don't know the price but the guys that can help you out are a company I use for my dozer. It is Polar Parts out of Savage MN. and the guy I deal with is Ray. He will be able to find anything for you and he will shop for the cheapest alternatives for you.
Jan 07, 2013 | Cars & Trucks
Need photos of alternator and starter wiring on 93 nissan 4wd - 4 cylinder truck yes please i disconnected and didnt label wires thought it would be faster it wasnt. its good lesson. the engine...
there are 4 wires go to alternator
2 white wires go to battery
1 black wire goes to ground
1 yellow/black goes to bulb check relay
starter has only two wires
the big one goes to the battery and the small one goes to ignition system. you can not mix the terminals because the size of the studs on the starter
Mar 07, 2010 | 1993 Nissan Pickup
The plug that connects to the alternator has three
Yes the White wire is the reason. It goes to the Internal Regulator.
As you view the connector that plugs into your alternator, look at where the lock tab is.
Lock tab on TOP. The Black wire goes to the Left side. The White wire goes to the Right side.
The Black wire, ties into the Red wire down in the wire loom. (The Red wire goes to the starter solenoid, and this is connected straight to the battery. This is why the Red, AND the Black wire, are both Hot wires)
The White wire goes through the bulkhead wire loom, and to the bulkhead connector.
(Down under the steering shaft, and on the firewall, you'll see a rectangular Black box shape, with a Bunch of wires, coming into it from the engine compartment. The bulkhead connector is two pieces. Following it through the firewall, the other side of it is the fuse panel)
Where the White wire connects in the fuse panel,
it should go straight to the ACC fuse. (Accessory)
May 15, 2009 | 1987 Chevrolet Camaro
Need help with auto wiring ( DON'T KNOW WHERE WIRES GO? )
located the wire coming from batterie light thats very easy you just have to aply groun to one of the 2 wire conector and the alternator light will come on with ignition on, be carrefull the other will have 12 volts, then the big and thick wire goes to the big post on the alternator, and the batterie light wire goes to the remainig small alternator wire, i belive must to be brown color
on alternator but can't remeber, good luck
Jun 05, 2008 | 1992 GMC Jimmy
Athearn HO RTR John Deere 650H Dozer Logo
328 people viewed this question
Top Athearn Toys Experts
Jay Finke
Jay Finke
Shehu Pro
Shehu Pro
Are you an Athearn Toy Expert? Answer questions, earn points and help others
