Question about Canon imageCLASS D320 Digital Copier
My printer display incorrect paper size and stop printing
My printer always display incorrect paper size after every one print though the correct paper size it feed into it and it will stop printer unless it is put off and on again through the main switch because it Start won't work.
Please what can I do.
  • 2 more comments
  • geneg1 Apr 24, 2008
    my D320 printer has the same problem, I try to change the settings of the driver, but still that is no such option. could you give me more detail troubleshooting? Thank you so much
  • yingbh Sep 10, 2008
    My Canon L170has the same problem...everytime it display incorrect papter size in cassette:A4. eventhought the file print out perfect ok it'll just stop to work.
    I change the settings but the problem is still the same.
  • HockeyGurl Oct 26, 2008
    i have a letter size paper in my printer, it says i have legal size and won't print...please S.O.S
  • Anonymous Mar 19, 2014
    trying to print a letter size document and the printer comes up with an error that there is no paper, but, there is.
  • 62 Answers
Try checking that the paper size settings in your printer driver ar set to either 'AUTO' or to the paper size that is being fed thru the printer. Let me know?
Posted on Dec 30, 2007
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
Printing pdf's, margins are wrong and cut off on top and left.
Choose the correct paper size of your printer for scanning and printer because I believe you select the incorrect paper size and it cut the pdf scanned file.
Go to printer icon, right click mouse and choose printing preferences and choose the correct paper size. Then go to scanning properties and choose the correct paper size.
Mar 16, 2011 | HP LaserJet 1022 Printer
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I have a hp photosmart c4280 and whenever i print it says margins are incorrect. how do i set them correctly so i can print documents.
Check the paper size at the printer properties on control panel.
You may be trying to print an A4 document to a printer configured to print on Letter size paper.
The document paper size should match the printer's paper size deffinition.
Nov 10, 2010 | Computers & Internet
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Printer will not print. Displays no paper.
Is the page stop at the back of the tray set correctly? If you have the stop a "click" off, rather then seeing letter size, it will see universal or A4 and say no paper, because it's looking for letter size. If it is on the network, just open a browser and go to the IP address of the printer, or print out a configuration report. That will tell you what size the drawer is reading.
Jun 16, 2008 | Dell 1600n All-In-One Laser Printer
From the manual:
If ink has run out while receiving a fax, if the paper size setting is incorrect, or if the paper type is set to a type other than plain paper, the fax is automatically stored in memory and <Received in memory.> is displayed. When the ink tank is replaced or the paper size/type setting is corrected, the stored fax is printed automatically.
Also, if the machine is in the process of something else (printing from computer, making a copy, scanning to computer), when a fax comes in it will be saved to memory, but it should print within a few minutes of becoming idle again.
May 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Check paper size message even though paper size is correct
Make sure when you send the print job, that manual duplex options are NOT selected.
Jan 16, 2008 | Epson Aculaser C1100 Printer
Help...hp k850 cannot print A3 size paper
download the new driver from HP site. And that is it
Aug 22, 2007 | HP Officejet Pro K850 InkJet Printer
Canon imageCLASS D320 Digital Copier Logo
1,081 people viewed this question
old marine
old marine
