Question about Bushnell Optics 2x12 260900 NightHawk Viewer Night Vision
Bushnell Nighthawk battery gone bad
Where can I find a replacement battery for a bushnell nighthawk?
  • 115 Answers
I would contact bushnell and send this in for repair. you can call them at 800-423-3537.
Posted on Oct 06, 2009
Nighthawk alarm Getting err code and beeping. Is this dangerous
A flat battery will sometimes gve this, replace battery as it may not be holding a charge
Feb 06, 2014 | 1982 Honda Cb650sc Nighthawk Motorcycle...
1992 Honda CB 250 Nighthawk no spark
Hi, Anonymous and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1993 Nighthawk 250 has no spark
How to diagnose no spark situation on motorcycle
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 11, 2013 | 1992 Honda CB 250 Nighthawk
I would like know list counties covered by your warrenty
I really don't know what other countries that Bushnell DNV covers. Where did you buy your Digital NV devise? Where do live? GB...stewbison
Aug 23, 2011 | Bushnell DNV Nighthawk Digital Nightvision...
Describe how to work the westinghouse timer
Hello, what type of Westinghouse timer do you have analog/digital? What is the model number?
stewbison
Aug 22, 2011 | Bushnell DNV Nighthawk Digital Nightvision...
I need an owner's manual
Hello. Go to this Bushnell URL site http://www.bushnell.com/manuals/night-vision/26-0900_Night_Vision_6LIM.pdf. This will give you owner's in about 10 different langage.
GB you...stewbison
walk gently upon this earth, and she will be good to you....
Feb 01, 2011 | Bushnell NightHawk 26-0900 Monocular
BAD TACHOMETER WIRE LOSE,NEED TO BREAK CIRCUT IN HEAD LIGHT ASSEMBLY TO STOP TACH FROM PICKING UP SENDER SIGNAL, IS SPIKING IN MY 2003 HONDA 750 NIGHTHAWK
Believe it or not, a bad battery or loose connection at the voltage regulator/rectifier can cause this problem. It is caused by the charging system surging.
Ride Safely, Ed
Apr 08, 2010 | 2003 Honda CB 750 Nighthawk
3-9x40 bushnell scope red dot wont come on???
I believe your model takes an 3V lithium battery type 2032. Grasp the battery cover and turn it counter clockwise until battery is exposed small screw driver, gently pry the battery free, replace it and, tighten the battery cover.
here is a manual
http://www.bushnell.com/manuals/riflescopes/Banner_Riflescope.pdf
download it an keep it for your records
should it still not function To make contact on your scope
Bushnel Performance Optics
8500 marshall drive
lenexa, kansas 66214
Dec 12, 2009 | Bushnell ® Elite® 3200 3 - 9x40 mm...
82 honda nighthawk 750
Possibilities are>
  • Wires not hooked up properly or a wire is disconnected
  • Bad rectifier or bad voltage regulator
  • Dirty or loose wire connections
  • Bad stator
Can I get a “very helpful” rating on this answer?
Aug 18, 2009 | 1992 Honda CB 750 Nighthawk
Bushnell Optics 2x12 260900 NightHawk Viewer Night Vision Logo
601 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
