Question about Cameras
Does a SanDisk Cruzer 8gb USB 2.0 flash drive that requires a high power USB port work in a HPzv5240US laptop computer?
  • 724 Answers
The new SDHD need to be seen by newer readers. A usb reads USB but the reader that is connected may not will not read the newer SDHD
Posted on Jul 27, 2009
Hello, my 8gb Sandisk light is keep flashing and is not bieng reconized by my laptop.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
good luck.
Feb 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My computer don't capte my cruzer
Then either the USB port is inactive or the drive is defective, try another device on the USB, if that works the drive has failed
Feb 16, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a Sandisk Cruzer 8GB pendrive. I was copying files halfway until a message pops out telling me that my drive is not there. i ejected and reinserted the pendrive, but I couldn't delete any files...
Right click my computer and click on manage. In disk management try to reformat as another solution for your usb storage drive. Try another usb port on your computer as well when you reinsert it and restart the computer. Usually when a usb device turns off and doesn't show up like yours did the device could be faulty or the usb port you have it connected to or for laptops sometimes the usb ports turn off if only using battery instead of ac adapter. There are power save modes for usb ports so have to check that in device manager as well. Good luck!
Dec 22, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I got amessage which say that USB Devise not recognize
There are different Ways to troubleshoot Your Problem
1. Verify if minimum operating system requirements are met.
2. Try other USB ports
3. Check status of the Cruzer under Device Manager
4. Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
*. check under Device Manager
  • 1. Right-click My Computer, and select Manage
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
*. 2. On the top menu, click Action then select Scan for hardware changes.
*... STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
Now the Other way
*. There might be a conflict in drive letters, see Resolving drive letter conflict.
Feb 19, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cruzer Micro 8GB flash drive - no user manual
Plug it into the USB port. Press Windows-E to bring up the Explorer window, or start My Computer and open the removable drive.
You can then drag&drop files to/from the flash drive just as you do on the hard drive.
Feb 22, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Cameras Logo
75 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
