Question about Garden
I have the homelite mighty light gas trimmer. The string does not stay out. Soon after I start cutting it goes back in
3 Suggested Answers
  • 6 Answers
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Posted on Jun 19, 2009
SOURCE: I am looking for a manual for a homelite gas
type in homelitest and ut number on the trimmer and then search google . maybe
Posted on Jul 11, 2009
The spinning device (the filament cassette I think) through which the cutting strings are attached has detached from the trimmer's stick. How can it be put back again or reattached?
There should be a knob that goes on AFTER the string spool that holds it on. IF the issue is it keeps turning when you try to put it back on, then on a machine with no clutch, the engine will need to be locked up. To do this, remove the spark plug and wire, pull on the start cord until you see (with a light) the piston go DOWN in the cylinder...then insert a length of soft, clean rope into the cylinder and this will lock it up when it tries to turn again.Parts on end of the machine are:
1. Bump Knob 2. String Spool 3. Spool Spring and finally 4. String Head Housing
Aug 14, 2011 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I feed string into my Homelite Mighty Lite 26ss grass trimmer? I don't have a manual and I can't figure it out. Thank you!
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 03, 2010 | Homelite Mighty Lite Lawn Trimmer
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
I am clealning ;up a homelite string trimmer, one adjusting screw. how can i know if i have the gas lines in correct places i know which line has the filter in the tank but where does it connect to the...
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor often connecting at the bottom to a short barbed stub.
May 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Refill string trimmer
ARE YOU WINDING TO LINE THE RIGHT WAY ON TO THE SPOOL?? FOLDING THE LINE IN HALF AND WINDING BOTH ENDS OF LINE SAME WAY? NEIL
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
