Question about Canon imageRUNNER 2020i Black and White Copier
Canon ImageRunner 2020i
Red light blinking and is showing Load Paper Tray : Free. We have paper in the tray but nothing is working. We can make copies but we can not receive any faxes. Please Help.
    Problem Solver:
  • 19 Answers
First do you have to selec the try with do you are going to use for copy.
Posted on Jul 28, 2009
Unable to print from canon imagerunner 3100
Select the paper source(paper tray) on the computer,select paper size.
Jan 03, 2012 | Canon Diplomat Office Equipment & Supplies
I have a canon imagerunner 2020I copier with a
this message is 90% from the second tray.try to close the small door of the 2nd cassette forcefully.if it does not work u can disconnect the second tray by unplugging the wire from the engine board on the back side of the machine by removing the back cover.it will be a yellow p/j in the middle of the board.u can easily trace it as it goes down to the 2nd tray.
Jul 13, 2011 | Canon ImageRunner 2020i Copier
CANON IC2020I INIDICATES A PAPER JAM LFT TOP OF THE SIDE DOOR. THERE IS NO JAM AND ALL SENSOR CHECK GOOD
try removing the p/j of second tray from the board after removing the back cover.I am sure the error is from the second tray sensor.in order to this error solve it u have to remove the second tray unit from the copier and then try to blow it throughly.
May 20, 2011 | Canon imageRUNNER 2020i Black and White...
Our Canon imageRUNNER 2270 is copy/printing sidways instead of normal. what happened?
I would look to make sure the paper tray's are set correctly in the paper trays... There is a knob that moves at will.... just kidding... Make sure that when you press on the diplay for paper size's, that if it shows LTR make sure the paper is in the tray going the short way.. LTR or you may have the paper tray set for LTR-R and you have the paper in the tray as LTR. I believe that the paper trays are set wrong. You may have figured it out already.. Good Luck
Nov 29, 2010 | Canon imageRUNNER 2270 Copier
Canon imageRUNNER 2020i left door paper jam error.how to reset Tried to clean everthying,and there is nor paper jam.
I have a Canon ImageRunner I seem to have a paper jam. The red light is coming on showing the jam in the upper section of the machine but I have cleared all the sections I know to clear. I have turned the machine off and back on the jam light is still on. I can't find the Manuel to see what the problem is. What should I do?
Nov 29, 2010 | Canon imageRUNNER 2020i Black and White...
We have a Canon Imagerunner 2020i and all of a sudden our copies are coming out offset and the screen says wrong size paper. We are using 8.5x11 paper for 8.5x11 copies.
Check the dial or slider on the side of the cassette tray for size indicator. This will cause jamming and the improper size message. Make sure the indicator matches the size of paper in the tray.
Sep 16, 2010 | Canon ImageRunner 2020i Copier
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
Copier stops after 35 copies when using finisher
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Jun 02, 2009 | Canon imageRUNNER 400S Copier
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Canon imageRUNNER 2020i Black and White Copier Logo
302 people viewed this question
old marine
old marine
