Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washer dryer won't power up
I have a problem with my Ariston Margherita 2000 - it won't power up. It hasn't blown the fuse in the plug, but I've just had to re-fit the belt as that had jumped of and sent the machine haywire. No loose connection that I can detect and the socket is fine.. Just a faint flicker occasionally of the red light when you switch on.
  • jon_heslop Jul 29, 2009
    Thanks for that. I've checked the motor and it's fine. Maybe it's the doorlock wiring? I'll check that later..
  • 28 Answers
Worn brushes on motor can cause machine to seem dead. No voltage trough motor.
Posted on Jul 27, 2009
Need a user manual for Ariston Margherita 2000 Mod. AC 80L s/n 303243031.
go on to the ariston web site with the details from the label as you open the door
Mar 19, 2014 | Washing Machines
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston Margherita Washer Dryer 2000 dries when not supposed to.
I think I am right in saying that on this machine you have the facility to either incorporate the drying process as part of a program or you can use it as a stand alone dryer, is it possible that you have simply asked the machine to dry after wash by selecting a wrong program is there a another button that allows you to wash with out dry even on a wash dry program if there is such a button/switch and it does not seem to do much it could be that the switch contact have corroded and are not making proper electrical contact check manuel
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Washing Machines
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Aristin Margherita 2000, motor is silent after I put the clothes
turn the wash temperature dial to zero,
if it starts to wash it could be a faulty thermostat,
if that wont wont work it could need new brushes in the motor
Mar 15, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Margherita 2000
put belt on motor pulley. start belt onto large pulley. turn large pulley by hand so belt will slip on. does require some strength
Sep 07, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Ariston Margherita 2000 (Advantage) Model A1435UK
Ariston Washer Dryer Margharita 2000. I have inherrited this machine but there is no user manual, does anyone know where i can get one from??
Mar 25, 2008 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
169 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
