Question about Passport 8500 Radar Detector
Escort 8500 X50 Red K & Ka bands going crazy
Escort 8500 X50 Red: K & Ka bands going crazy in the city.
It will go off like crazy for about 6 block stretch & then nothing.
A few days later, it goes off only intermittingly.
Thanks
  • GoneToPlaid May 11, 2010
    Are there any microwave door openers in this area? Also, satellite dish systems use Ka band amplifiers. The Ka band false could have been caused by an older model satellite dish system which was powered on one day but not when you drove by the location later.
As other users said the cleaning took care of the issues. So I took their suggestions because nothing to lose. I took it apart. It is very easy. Just remove 3 crews at the bottom. It has one snap-in hook at one of the corners but easy to separate it. Then I removed the metal part (aluminum die-casted, silver color) from the PCB. It is easy to remove, just remove 6 screws (I think it is 6) then pull the thing out. Inside the aluminum die-cast part is dirty. If you clean inside with Q-tip, you can see the nasty stuff comes off. I think what happens is that the nasty dust comes off then stick on the sensing elements, which might have caused false signal. Also I cleaned tiny elements inside the metal piece with Q-tip. Now it seems working normal. Hope it stays normal. Give it a try if your unit does not act normal. Better than spending $$. Good luck!
Posted on Sep 04, 2009
Returned unit to Escort.After 2 months of misleading info, returned "repaired unit". Only problem is they returned wrong unit. Different serial #. So I am back to square 1. If it's microwaves, or sattelite dishes, why does it not behave the same each time I pass through?
I now don't believe ESCORT'S claims - these units are not good in the City!
What wire to solder on the ciggy plug?
Red is your positive black is ground yellow constant power green is a wire that does not need to b used nor the yellow unless u want constant power to the unit positive red wire goes to the front of your ciggy adapter black can go on edit hie side of the two grounds that hold your ciggy adapter inside the socket hope this sheds some light on it
Mar 03, 2014 | Passport 8500 X50 Radar Detector
Constantly going off
is it going off with X Band? If so thatere is a way to put it to filter out X Band I have a Redline but it has the same features as yours just follow the manual to go and have it filter X band radar. Also K band will go off as well when you are in a city by automatic opening doors which is normal.
Jan 31, 2014 | Passport 8500 X50 Radar Detector
Comes up service required. fault code cal7. ka band not functioning. any solution?
CAL7 is a broad self-test failure code. It will have to be sent to Escort for diagnostics on the specific problem unfortunately.
Nov 12, 2010 | Passport 8500 Radar Detector
Keeps going off randomly.
if its when your driving, then its picking up alarm systems.
If you are not on a major highway this is less likey.
the unit has city mode and highway mode.
If you put it on city, it will go off less from alarm systems.
Dec 05, 2009 | Passport 8500 X50 Radar Detector
Changes from auto to hwy to city on its own
The problem is a defective micro switch underneath the City button. Contact Escort about setting up a RMA to get your X50 fixed.
Jul 22, 2009 | Passport 8500 X50 Radar Detector
Put Escort passport 8500 X50 into calibration mode.
If you hold down the mute button (on front) and the two buttons on top...when you power up, it will reset.
Mar 20, 2009 | Passport 8500 X50 Radar Detector
I have a passport excort 8500 X50 that signals maximum Ka and X over and over.
Are you getting any Self Calibration or Service Required error messages? If not, then this means that the basic electronics are good and that the problem is within the antenna. If your X50 is in warranty then Escort will repair the antenna for free. If not, then there will be a service fee ($80). Yet I can all but guarantee you that after Escort fixes the antenna problem then you will never have this problem again.The service fee also includes fully testing and calibrating your X50, and updating its internal computer firmware code to their latest code. So the end result is that your X50 will perform just like a brand new one.
Jan 25, 2009 | Passport 8500 X50 Radar Detector
Passport 8500 Radar Detector Logo
438 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
