Have a goodman air condition GSX130361DA but the thermostat is by honeywell.
Clear the drain line with a shop vac and empty the float switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Testimonial: "thank you sir but i have no idea where the drain line is or the float switch. please help me with that. is it outside where the 2 air conditions is?????"
The float switch is usually a section of the drain line itself and will have two wires leading to it. Or your a.c. is sitting inside of a metal emergency pan that is full of water and has a float switch on it. Look near the indoor unit. Obviously the end of the drain is located outside and this is where you should likely vacuum from
a/c is working. thanks for your help
SOURCE: Honeywell theromostat not working
check the control fuse and the step down transformer or wiring between the thermostst and the unit
SOURCE: just moved in yesterday and
Sounds like the programming on your thermostat needs to be reconfigured, but I need more information like the Honeywell Model number which can be found behind the front cove, but becareful to unsnap the t-stat properly not to damage the pins that connect t-stat to its base.
SOURCE: Home air condition thermostat is blank. My home's
Snap the front cover off the thermostat and replace the batteries
