Question about Refrigerators
My kenmore refrigerator is now making a crackling sound when it's running
  • 77 Answers
Check condensor fan area and clean condenser area
Posted on Jul 28, 2009
My Breville digital toaster is making crackling noises.
your question is under coffee maker category and it is about toaster.
Anyway your toaster should not make crackling noise indicatve of arching. If it has run its life, change it
Nov 18, 2013 | Breville Coffee Makers & Espresso Machines
1985 kenmore s by s. makes snap, crackle and soft pop sound from back of fridge. Only when running it makes that sound.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 05, 2011 | Refrigerators
Refrigerator will not defrost
Remove the kick plate grill at base of refrigerator and turn the timer clockwise slow until compressor stops. That should be beginning of the defrost cycle. After a few minutes look inside freezer or listen for crackling or hissing noise. That should indicate defrost. After 25 minutes if it does not restart then turn again until it restarts. Replace defrost timer. Let me know what happens, Thanks Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Kenmore trio won't make ice
my ice maker won't make ice and sounds like trying to run water into it but isn't filling it up
Sep 11, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Refrigerator runs very loudly
If sound is coming from freezer it is probalbly the evaporator fan. Either the fan is bad or the fanblade is making contact with something.
May 31, 2009 | Kenmore Refrigerators
Kenmore coldspot #59597993
Check the condenser where heat is removed from the system. Look under the front behind the toe plate under the door. Use a vacuum crevasse tool to get into the narrow places to draw out the dust and lint. Make sure the fan under the refrigerator is running. You can remove the bottom panel in back to observe the fan operation. Listen for sounds at the back like a hum and a click. Check the compressor to see if it is hot and running. If the compressor is cold you may have a control problem.
Jun 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator is noisy
my kenmore fridge is loud everytime the compressor comes and stays on. I have developed tinitis in the year because of this noise. Solution to this problem : I will never ever buy another Kenmore refrigerator.
Mar 05, 2008 | Refrigerators
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
