SOURCE: krups coffee machine
The krups website does have a listing for where to send in for service in China,. That website is www.krupsusa.com
SOURCE: Instructions Manual f. Krups Coffee Machine963
Solved this problem simply by trial and error attempts!
SOURCE: We have a krups combo expresso and coffee maker. I
When is the last time you cleaned it out w/ vinigar?
SOURCE: I have a 12 month
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
SOURCE: Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
sorry of courae the correct model type is xp7200
the question to remains the same
hiw to reset the software
thanks
You do not reset the software for error 6, you fix the fault and error 6 will disappear. Error 6 on that model is most commonly a leak or a fault with the distributor which the fix is replacing it.
thank you sounds good
now when I take the cover off where is the distributor?
before defect machine had 47 coffees before cleansing
i teied cleansing though machine stopped working
The distributor is the motor driven tap on the right side down low. Opaque plastic colour with silicone pipes attached with stainless steel hose clips.
