Question about Sunbeam Grill Series 550
I need a part number for the venturi
I need to get the part number for the venturi so I can order a replacemnt burner. My sunbeam grillmaster model is GG550WPP. I cannot find the manual. Do they have manuals online? What is the 8 digit part number for two venturis?
    President:
  • 1,734 Answers
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
Grillmaster burner no gas
Check and see if burner is blocked or injector to the burner is blocked
If you swap 1 of the buners over this will show you what is blocked
Jun 24, 2012 | Sunbeam Grill Series 760
What size orifice do I need for 12,000 btuh burner
why not just buy the kit to convert it ?
May 11, 2012 | Sunbeam Grilling
I have a 2005 Weber Genesis Silver propane grill. The first and third burners work fine, but the middle burner will not ignite. I have cleaned it and still no flame in the middle. I'm about to order...
Jeanne - Did you remove the burner to clean? If not. you weren't able to clean the Venturi Valve, which is part of the burner. Spiders love to get in the Venturi Valve & build a nest. When that happens it stops the gas to that burner. I suspect, that may be the problem. The Venturi Valve, is part of the burner (the open end part) that's closest to you, when you face the front of the grill. It will look like 2 slots (one on each side) cut out of the burner tube, where it fits over the burner orifice. But, you can't see it, without removing the burner. An old tooth brush works well to clean it.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
Jun 19, 2011 | Weber Genesis Silver B Grill
Hi there i was wondering if you knew the part number for the sunbeam 650 grillmaster burner??? Thanks a ton!!
here is the website, Good Luck Tim:
http://www.clagrills.com/parts/sunbeam_grillmaster/sunbeam_grillmaster-parts-home.htm
May 31, 2011 | Garden
Hi! Hope you can help us--we have a Brinkman 4-burner grill that is about 5yrs. old. Last yr. we started having problems with burner #2 not lighting all of the way and the burners all looked a bit rusty,...
I think you husband is trying to clean the wrong thin. The venturi tube is part of the burner itself. It's the open end of the burner, that has an air intake adjustment on it. It fits over the burner orifice. He may be hitting the orifice, which in fact may be clogged. Remove the offending burners and he will be able to see the burner orifice, which can be removed with the appropriately sized wrench. Once removed try blowing through it. If air doesn't blow through, it's clogged. Clean it with a straight pin that is no larger that the orifice hole. You do not want to enlarge it. Also, the new burners may need adjustment of the venturi for the proper air to gas mixture. Consult you Owners Manual on how to adjust it.
Need an Owners Manual? Go to http://www.brinkmann.net/my_grill.aspx and enter the Model Number of your grill.
Hope this helped you to solve the problem. Please don't forget to rate my response to you. Thanks!
Mar 27, 2011 | Grilling
Thermador sgcs365rw - I need to replace the cover for the on/off light. To access it I need to open remove the cooktop but one of the venturi is stuck fast. How can I undo it?
Hello- You got lucky and only have one stuck, unfortunately you will need to order a few more parts. The only way to get the venturi out is to drill it off, drill it down enough that you can get the burner around what use to be the nut portion of the venturi. You will also need to get the orifice holder that the ventrui screws into under the cooktop. These parts are pretty cheap. You could try to put some LIquid Wrench around the ventrui overnight but be sure not to try to force it out too much because the gas supply tube to that burner can get creased if the orifice holder starts to turn... What works best for me to drill the venturi is a countersink, preferably for metal, which has it's largest diameter bigger than the outside of the venturi. Get some cutting oil and start drilling, the ventrui's cut pretty easily but take your time and try not to damage the burner. Once you get down real close to the burner you can try to carefully pry the burner over the remnants of the venturi. Good luck, hope this helps. Best regards.
Sep 27, 2010 | Thermador SGS36GS Gas Cooktop
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
Can I still get a replacement burner assembly and venturi for a sunbeam 350?
Yes. From Modern Home Products it is part# SBT21. From Music City Metals it is part# 15902.
Nov 10, 2009 | Sunbeam Grill Series 350
Venturi tubes
The venturi tubes should go over the gas orifice. If the tubes were to drop off, you could have a fire outside of your grill and possibly an explosion.
Jul 03, 2008 | Sunbeam SG6622RP Grill
Bravetti hand mixer beaters
amazon for sure... take a look here: Enjoy Life Sweetest Moments with Sunbeam. I hope I have helped. cheers
Jan 13, 2008 | Food Mixers
Grilling Logo
162 people viewed this question
Top Sunbeam Grilling Experts
Gil Shultz
paulcarew
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
