SOURCE: Instructions for ladies' Armitron 45/6974
From the instructions that came with the watch:
Press the button at the top left to get into time change mode, press on the bottom left button to move between seconds, hours, minutes, etc.
Press the top right button to change numbers; hold to move quickly.
SOURCE: Armitron WR165 watch - changing time
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
SOURCE: I have a Ladies Armitron All Sport watch Model
Follow this link and find instructions for your watch:
http://www.armitron.com/watch_instructions.asp
Do not forget to rate, please.
SOURCE: How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given
their positions relative to where numbers would be on the face of an
analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The
options appear in this order each time you press the "ST/STP" button:
minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
SOURCE: setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
