Question about Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan
Fan went from low to high in the middle of the night, won't
Return to low or any speed but high. Light works correctly. Changed battery but no better results.
  • 5,568 Answers
I suspect it isn't correctable with a battery change; the speed control element (an unknown semiconductor) has shorted and no longer can control fan speed.
I'm not sure where this is located but is likely an assembly in the hub of the fan itself or with the control in the wall. These are often not repairable items and must be replaced.
I think Hampton Bay is a Home Depot house brand and the might be able to help you.
Posted on Jul 27, 2009
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
HUNTER FAN PART # 85095-1
Either need new transmitter or receiver or both. Call 1-888-830-1326 to order parts.
Jan 07, 2013 | Hunter (25417) Ceiling Fan
High low fan motor
Your main concern is the temperature difference across the indoor coil for both heating and cooling. When you turn your thermostat from auto to on, you are on high speed.
If you have long duct runs and little return air registers then high speed
would help cool the house better. However in the heating mode, you
could lose up to 10degrees by having the high speed setting.
What they installed is sized for your house and the speeds should not have to be changed unless the ductwork is not sized right for the house.
Cooling should be High-Black wire.
Heating should be Low-Red Wire.
400cfm equals a ton of cooling= 1200 sq. foot, For cooling you need
High speed. For heating it is whatever the temperature rise across the
coil is, which is located on the furnace/air handler.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Fan speed went from low to high in middle of night
The low and medium speed wire of the chain switch probally connected to the high speed wire. Open the cub and disconnect them.
Jul 27, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
I HOPE I AM USING THIS PROPERLY......MY ? IS IN MY
The indoor blower motor is sometimes a 3 speed motor.The heat usually works on low or medium speed.But the a/c is usually on high speed,this gives greater air flow across the evaporator coil to give you better cooling,also better air flow at ducts.These speeds are usually wired through a relay in the inside unit (air handler).They can be changed.If you go to thermostat and put the fan switch to "on" the blower should operate on "high" speed.With the fan switch set to "auto"the operation will determine the fan speed.Hope this helps. Gregg
Jun 04, 2009 | Heating & Cooling
Hampton Bay AC414-LRU 52'' Kemper Collection Rustic Finish Ceiling Fan Logo
100 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
