Cars & Trucks Logo
M
Michael Bissuett Posted on Aug 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove a 2004 coupe de ville cadillac battery
  • Lonnie Arks Feb 27, 2020
    Personally, for testing or replacement of the battery, I recommend the local Sears auto shop. They can check the entire charging system and, if needed, provide a most excellent battery. Yes, it is under the back seat (just like my 1965 VW beetle LOL).
Jeff Armer
Level 3:
  • Cadillac Master 15,575 Answers
  • Posted on Aug 02, 2017
Jeff Armer
Cadillac Master
Level 3:
Answers
15575
Questions
Helped
7111336
Points
73899
Video on youtube . A picture is worth a 1000 words .
02 deville battery install
Thomas Perkins
Level 3:
  • Cadillac Master 15,088 Answers
Thomas Perkins
Cadillac Master
Level 3:
Answers
15088
Questions
0
Helped
3389417
Points
54869
logmgr
Level 1:
  • Contributor 3 Answers
logmgr
Contributor
Level 1:
Answers
Questions
0
Helped
1323
Points
7
I have a 2003 Deville...battery is under rear seat ...pull seat up and out to raise....battery itself is very easy to change out.
javascript:;
5 Related Answers
motor1258
Mike Butler
  • 6674 Answers
  • Posted on May 10, 2009
SOURCE: power windows quit working
On a 77' I'd go directly to switch & check for power there, if none, and your sure all the fuses etc have been checked and are o.k., take a good look at the door jamb area where harness is near hinges for a break or corroded wire in the loom that folds when door is closed & opened. See if you have power coming through that area.
Anonymous
  • 135 Answers
  • Posted on May 20, 2009
SOURCE: can not get wiper blades off a 73 coupe deville
insert scewdriver between wiper blade and wiper arm and apply a little force to remove wiper blade
Anonymous
  • 22 Answers
  • Posted on Nov 06, 2009
SOURCE: I lost my key to my 1963 Cadillac coupe DE ville I
Ive been told that gm can cut a key using the information in your vin number. I wouldnt know if gm would still have records from 1963 to help them cut a key but it would be worth a try.
Kravcar
Mark Carrington
  • 192 Answers
  • Posted on May 22, 2010
SOURCE: what is the correct temp on a 1998 Cadillac DE
The normal coolant temp should be around 200-215 degrees.
The cooling fans will come on at around 225-228 degrees.
The most common overheating problem with the Northstar engine is a blocked purge line(small hose).The purge line is designed to purge air out of the cooling system.
There is a small diameter hose coming from near the top of the coolant tank (not the cap) ,this is the purge line.
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.
If the hose is clear, check for blockage at the nipple on the tank.Or trace the hose back until you find the blockage.
The hose goes in to the engine to a crossover and comes out the other side close to the thermostat housing,the blockage may be there.
kirkx
Kirk Augustin
  • 2019 Answers
  • Posted on Oct 07, 2010
SOURCE: Cadillac 1989 oil change What is the best type of
Castrol 20w-50 in summer and 10W-40 in winter, is best in my opinion.
It is high detergent, to remove sludge.
The thinner oil, like 5W-30 is only for better mileage, but cause piston and camshaft wear.
Testimonial: "Thanks for the answer!!!"
Where is the fuse for the fuel pump on a Cadillac coupe de ville 1984?
the relay and fuse panel that is to the left of the main fuse panel
the pump relay,is in position #10.
Flushing the system in my 2004 Deville
see link below for how to flush 2004 cadillac de ville
How to flush 2004 cadillac deville cooling system
http://www.fixya.com/cars/t12393977-flush_2004_cadillac_deville_cooling
I want to remiove the door trims on my 2 door 1974 Cadillac Coupe de Ville.
ex to do, lower window, remove screws around door handle and arm rest the panel is held on with plastic clips around the outer edge they pull straight out using a flat door handle removal tool works well
1helpful
Can't open the back doors on 86 cadillac de ville
Automatic ?? You should be able to unlock the doors from the inside and open them. If someone set the child safety locks you may have to remove the door panels and unlock from the inside of the doors.
I intend to re glue the billowing headliner back up on my '88 Coupe De ville. How do I remove the interior trim for access, please?
easier way: 3M has a spray contact cement for this that has a very small extension tube that you poke thru fabric and spray, work from center outward for best results
I lost my key to my 1963 Cadillac coupe DE ville I was curious how I should go about replacing it.
2answers
Can not get wiper blades off a 73 coupe deville
1helpful
2answers
Where is location for the shift solenoid on a 1992 cadillac de?
The shift solenoids in a 1992 Cadilliac Devillie are on the drivers side of the car, open the hood look at the right side of the motor you will see the upper part of the transmission housing you will see the pan in side the pan are 4 solenoids A and B -TCC - PWM the transmission is a 4T60E you can buy a kit with all 4 for 70.00 at Electrical advantage.net
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
