SOURCE: adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
SOURCE: Dim Picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: Picture dark
The problem lies with a resistor on board the power circuitry. Buy a multimeter and check the power supply part checking each resistor. The part where the meter doesn't fly, means that resistor is burnt. Change with same rating and check the display.
SOURCE: Infocus 61md10 picture is very
I would change the lamp. And NO, you cannot use any other intensity other than the original.
SOURCE: how can I adjust my
If you have MENU button on your TV, then press it and check for brightness. For best results, you can get the manual and solve the problem. Look into the system, not so hard and just apply some skills, your onto it.
