Question about Canon I960 InkJet Photo Printer
1 green 10 yellow flashes - Canon I960 InkJet Photo Printer
    President:
  • 2,306 Answers
10 flashes says that auto duplex printing is not possible, or the auto duplex unit is not installed...
Posted on Jul 27, 2009
Flashing lights green and yellow 10x and the printer head is stuck to the right
10 times
B200 VH monitor error.
You will have to replace the printer.
Nov 01, 2013 | Canon PIXMA iP3300 InkJet Photo Printer
I have a Jazzy 1120 When I turn it on all the battery lights flash rapidly any suggestions
How many are flashing? There are 10 lights, if all are flashing (3 red, 4 yellow, 3 green) that indicates Code 10 and high battery voltage.
Apr 03, 2013 | Pride Mobility Products Used Jazzy...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Blinks green, yellow, green yellow
Anytime it flashes green and yellow there's a service error, but you need to count how many times it flashes between the longer green flashes, that tells us the error code.
Oct 28, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Green and Yellow Light blinks when I turn on my camera
HA, I got the exact same symptoms on my C5050!!! First the yellow light flashes for 10 seconds then the green one flashes. I believe the internal fuses are blown, there are 2 and they are surface mount so they are like 2x2mm so they are SMALL. Im going to have to jump them with a blob of solder on top. It is useless in its present state
Nov 10, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Canon I960 InkJet Photo Printer Logo
70 people viewed this question
old marine
old marine
