Question about HP GM325AA#ABA 2 Speakers
I am getting a distorted sound from the speakers. i did not receive an installation CD, not sure if this is the problem
  • 29 Answers
If you mean the xp/vista/win 7 installation cd's then you have to make your own. The manual that came with the pc will give you the information that you need. If it's xp it will be 1 dvd, vista needs 2 dvd's or 7 cd's, i'm not sure about win 7. As for the sound, what you could do is to drop the drivers for the sound card and reboot the pc, this will refresh the connection between hardware & software. To drop the drivers you need to go to start>>right click my computer>>properties>>hardware tab>>devise manager>>click on + sign next to "sound, video & game controllers & look for the sound card. Do not remove codecs, just the sound card then reboot.
Hope that works for you!!
Posted on Jul 27, 2009
At low volume it is fine after you get to about 20 on the volume it starts to crack,pop and distort very bad what is making this happen
Your speakers may say 350 watts but that is the peak wattage at which they blow up and not a wattage they can sound distortion free at. Look for the RMS wattage which is probably around 40 watts. If you look at the specs on your receiver you will see it will put out a maximum of about 50 watts but the distortion on the receiver is above 1 percent at anything over 22 watts. That means they are going to start distorting at around half volume. The other thing you might check for is a impedance mismatch between the speakers and the receiver. Is the receiver set up for an impedence output of 8 ohms but your speakers are 4 ohms impedance.
Aug 23, 2015 | Kenwood KDC248U CD Car Stereo Receiver...
When i turn the head unit up to about 10 it sounds good but then it gets all distorted like my speakers are blown but when i pou the stock deck in the system freaken rocks whats the deal with that
it sound like a wire problem you brobably would not hear the distortion with the stock deck because the more power the less distortion there is.
Oct 25, 2011 | JVC KD-PDR30 CD Player
Can a power conditioner improve distortion sound on center channel speaker? I have a Pioneer vsx 1020K receiver and I am only having a problem with the center channel. At first I thought the problem was...
First; power conditioner won't do anything for your issue. It's not crosstalk (unless it's a wireless spkr) On your sub are cables mark + & - ? If so make sure they're attached accordingly to back of receiver/amp. Your distortion sounds like a phase issue. I'm also curious how store performed diagnostics?
Mar 07, 2011 | Pioneer VSX1020K Receiver
Sounds like polarity is wrong on one of the speakers?
you have to make sure the speaker's are connected properly (positive out to positve in negative out to negative in)
Jun 04, 2010 | Yamaha HTR-5730 Receiver
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
Distortion using rear speaker interfaces.
yea get new speackers or u have a very low quality wire also can bet out of eq
Apr 02, 2009 | Pioneer VSX-1018AH-K Receiver
Center Speaker Audio Very Distorted
Love your screen name.
You didn't say what, if anything, preceded the appearance of the problem. There might be a clue.
Can you describe the distortion? Is it excessively bassy? If so, is it happening on all sources?
I'm assuming this is a modern digital receiver that is capable of many soundfield simulations as well as native Dolby Digital, DTS, multi-channel. If so we can use a stereo source and through simulation redirect some of it to the center speaker.
Using one of your receiver's many multi-channel simulation modes, put in a CD or tune an FM station and use it to diagnose the problem during later steps.
If it's only a single source and that source uses individual analog channel RCA cables, swap in another one or temporarily move the Center Channel feed to one of the other channels to see if it's before the receiver (in the source).or inside the receiver.
For multiple sources:
Is your Center speaker defined properly as Large or Small in the receiver's setup menu?The size refers mostly to the bass-handling capacities of all your speakers rather than their physical size. Speakers designated as 'Small' will not be sent much in the way of bass because they can't handle it well. The LFE/subwoofer channel(s) will get all the bass that was intended for them instead.
If you have a Small speaker improperly defined as Large it may be getting bass that it can't handle and that might sound like distortion. Having a Large speaker defiend as Small would result in less bass than expected but otherwise 'clean' sound.
Check the speaker setup in the menu for excessive volume level relative to the others. There is usually a calibration procedure the receiver will use to help you adjust the subjective voume of each speaker using white noise or tones.
Hope this helps.
Jan 18, 2009 | Sony STR-DE475 Receiver
Distortion on speakers from CDX-M630
sounds like you have a faulty head unit
Sorry
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Sony CDX-M630 CD Player
Distortion
YOU SHOULD NOT PLAY CD,S IN SURROUND SOUND,SWITCH TO STEREO ONLY FOR CD,S AND OTHER MUSIC SOURCES.
HOPE THIS HELPS.
Dec 17, 2007 | Onkyo TX-SR500 Receiver
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
HP GM325AA#ABA 2 Speakers Logo
163 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
