Question about Dell 0Y3740 Keyboard
Trouble Replacing Laptop Keyboard
I need to know how to connect and where to connect the keyboard connector on my Inspiron laptop. The manual told me how to remove it but not how to reconnect it.
  • 31 Answers
Good if manual told you how to remove then it is simple assembly is the reverse of disassembly.So follow this process critically and take note of what you are doing.
Posted on Jul 27, 2009
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
The letters "b" and "n"
there are programs you can use to erase the password but it is very easy to replace the keyboard.
I would suggest you type buy Dell Inspiron keyboard in to google an do the same on Ebay.
I did this for my friends laptop, the keyboard cost less than 10 pounds and had 2 ribbon connectors to remove the coffee stained old one.
You will need to buy some micro screwdrivers to open up the laptop.
No special skills are required to change keyboards, just give yourself a good bit of room on a desk to have the removed screws to hand.
Nov 30, 2010 | Dell 0Y3740 Keyboard
Alot of keys aren't working.
================================= I have the same problem wih my Dell Inspiron 8000 and it had a keyboard issue with keys I, J, N, PgUp, H not working.
ut when I took off my keyboard and reseated the ribbon connector and it's been working since then.
=================================== Please read instruction for keyboard replacement: http://support.dell.com/support/edocs/systems/ins1300/en/sm/keyboard.htm =================================== If it still not working I suggest you get a keyboard replacement. ================================== Disassembly Tutorial for your Laptop: http://www.insidemylaptop.com/remove-motherboard-repair-dc-power-jack-dell-inspiron-1300-b120-b130-laptop/ ==================================
Let me know if you need further assistance. Please Rate. Thanks and More Power!
Apr 23, 2010 | Dell Inspiron B130 Notebook
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
Keyboard connector on motherboard dell inspiron2200
personnally I would not try this. If this is the only laptop you have. now if its just a machine you tinker with you can try it. but for functunality I would leave the keyboard intact incase you ever want to use the portability of the laptop.
Apr 16, 2009 | Dell Inspiron 2200 Notebook
Dell inspirion 1521 keyboard replacement
You can find the description about replacing the keyboard here.
Don't forget to unplug your laptop form the power and to remove the battery before you start. You also have to take the hinges off.(How-to is here.)
Be very careful when you take the keyboard off, so you do not damage the very delicate connection cable!
Remove the keyboard connection plug GENTLY!
Jan 05, 2009 | Dell Inspiron 1521 Laptop
Dell inspiron laptop
You will need a usb based keyboard to connect it to your laptop.but if you don't have usb keyboard ,go to the computer shop and ask him for the ps2 to usb connector...
Good Luck !
May 30, 2008 | Acer Aspire 5100 Notebook
Replacing dell 2200 keyboard
Here is the documentation for dell inspiron 2200. You should refer to the service manual. In any case be aware that changing a laptop keyboard generally is not an easy operation for a beginner.
cheers
Feb 16, 2008 | Dell Inspiron 2200 Notebook
Laptop Keyboard Not Functioning
Try to unplug and plug back in the keyboard connector ribbon onto the motherboard. Consult the laptop manual if that voids your warranty or not before trying, also look at the documentation on how to dissemble your laptop, it shouldn't be too hard. here's the instructions on how to do it
http://support.dell.com/support/edocs/systems/ins2600/en/sm_en/keyboard.htm#1005330
you might need some tools, but good luck and be careful
Dec 22, 2007 | Computers & Internet
Fujitsu Siemens Celsius Mobile H KEYBOARD NOT DETECTING
if u r using the connector make sure none of the pins are not bent if u r not make sure the bios settings are correct if this does not work either it must be the battery needs replacing.(the keyboard uses a battery read the manual)
Oct 13, 2007 | Fujitsu Siemens CELSIUS Mobile A Notebook
Dell 0Y3740 Keyboard Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
