Question about Asko D3251XLHDSS Stainless Steel Dishwasher
I have the exact same dishwasher and the exact same problem.
Keeping the top rack out of the way when loading or unloading the bottom rack is not possible...empty or full the top rack rolls out half way.
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
ADJUST TENSION DOOR
Just below dish loading door there is a panel. Remove screws (if applicable) to find tension adjustment. Turn screw to the left to loosen or opposite lifting door open or closed untill happy with tension. Some washers have no adjustment, I suggest opening door fully and pulling out bottom load tray, loading and then top tray or rack, pushing top in first then bottom rack. Use a glass fry pan cover or fry pan for weight on door while filling soap. Good luck, best regards
Jan 31, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
My dishwasher cleans the bottom rack but doesn't get the top rack clean, and I'm not blocking anything or over loading. Any ideas?
there is a trap in the bottom of the dishwasher. Have you made sue that there is nothing stuck in there or anything blocking from the bottom?
Apr 16, 2009 | Dishwashers
Spray tower fell off
The Spray tower fits in the bottom rack, Its actually pretty obvious as there is no way it can sit int he position it has to without being in the rack itself otherwise the rack and tower would block each other all the time.
 Examine the base of your spray tower it should have two "clips" or plastic protusions that will, with a circular twist, snap onto the bars of the middle of the rack itself. Then when in place and your rack is slid inside the dishwasher the tower should sit directly over top of the exact middle of your bottom spray arm.
et Voila.
Nov 09, 2007 | Kenmore 24 in. 16309 Built-in Dishwasher
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Asko D3251XLHDSS Stainless Steel Dishwasher Logo
27 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
