Question about Maxim Coffee Makers & Espresso Machines
Where can i get instructions for maxim mx29-20 coffee machine
How I can get the instructions for a coffee machine DR.Tech Me 708
Have you ever heard of the Internet? Type in them words (Instructions, DrTech, coffee, Imsodumb) and see what happens.
Jul 05, 2014 | dr. Tech Commercial Grade Fully Automatic...
My coffe comes out too watery. the grinder is set at max (fine grid) is there another setting for the water? or to maximize coffee grinds?
Remove all the beans in the grinder chamber, then remove the screws and slowly lift the chamber about 1 inch high, then turn adjustment knob 3 numbers back and lower chamber making sure the gears on the bottom line up.
Feb 28, 2011 | Saeco Incanto Classic Espresso Machine
I have a expresso cappuccino maker model CC30. It is a Maxim-it is white with a red push button on top.. Does anyone have instructions for this..i don't and need some.. Thank you-gerry
nothing to know, put water in it..plug in..no steam should be coming out, until you push the red lever..put in your milk or cream
stick probe down at bottom of cup. steam until mixture gets thick
Jul 13, 2010 | Salton CC30 Plus Coffee Maker
I need an instuction booklet for my salton model ex 96 esspresso machine
Go to:
http://www.coffeecrew.com/learning/185-the-salton-maxim-ex96-manual-for-everyone
Jun 04, 2009 | Coffee Makers & Espresso Machines
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Where can I buy a replacement espresso pot
Update: Salton replacement parts and owners manuals can be ordered at 800-233-9054 or by emailing consumer_relations@toastmaster.com
Jan 30, 2008 | Bodum Chambord Style (8 euro/ 4 usa cup)...
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Maxim Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Maxim Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
