When watching my Quasar vv2025 tv, a black square comes on and nearly convers the whole tv. When I press any button onthe remote, the square goes away, but then comes back in a few minutes. ANy help on how to fix this would be great! Thanks, Steve KAne
  • 10,594 Answers
Please go to TV Menu and turn off/ disable CC (close caption)
Thanks.
Posted on Jul 27, 2009
What is the TV Code for programming the remote control for Quasar TV model # v v 2018 w ? Thank you.
Hello
Four digit universal remote control codes for Quasar Tv are:-
0171 0148 0054 0170 0062 0374 0381 0003 0070
Three digit universal remote codes for Quasar TV are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
OK.
Dec 08, 2010 | Quasar Televison & Video
Black square appears on my Legend TV
Check to see if you have text turned on in the closed captioning menu.
Jul 26, 2009 | Televison & Video
Trying to get my TV can't find manuel or remote
Press the "Input" or "Source" button on the television while you have the DVD player on. Press it repeadly until you see the DVD picture on the screen.
Basically, just try changing the input on the TV to the input that the DVD player is hooked to.
If this doesn't work, you may have to get the original remote, or get a universal remote to control some of the television's features.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Televison & Video
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
RCA universal remote
I programmed an rca universal remote by:
TURN ONTHE TV
HOLDING DOWN THE TV ANDTHEON/OFF BUTTON ATTHE SAME TIME.UNTILTHEON/OFF BUTTON STAYED ILLUMINATED.
PRESS THE PLAYBUTTON IT WILL BLINK,IF TV DOES NOT GO OFF PRESS PLAY EVERY 5 SECONDS UNTIL TV GOES OFF.
ONCE TV TURNS OFF HIT THE REVERSE BUTTON THE TV WILL COME BACK ON.
HIT THE STOP BUTTON TO SAVE THE CODE.
REPEAT THIS BUT HOLD THE OTHER DESIRED DEVICE INSTEAD OF THE TV.
HOPE IT WORKS
Igotthisinfo from google....then typed in rca universal remote...there was a sight for programming remote.
Jul 26, 2008 | Sanyo DS24425 24" TV
Using a portable dvd player
that's the one of the closed caption options in the tv set. on your remote control there should be a button labeled "cctv", cycle through the options untill you find the off mode. this could also be in the tv menu.
Apr 27, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar VV-1302 13in TV/VCR unit. Remote stopped working
Test your remote by placing it in front of a video camera or web cam if you have one.. Press the buttons and watch the cam to see if you see the light coming from the remote.. The camera lens merely slows the light to a visable spectrum.. If no light your remote is not working... If light replace the sensor in the TV..
Bill
Jan 14, 2008 | Quasar VV-1302 13 in. TV/VCR Combo
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
