Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Magice Chef side by side builds up ice on freezer floor
Model CSD2123 AR get 1-2 inches ice on freezer floor every couple days see solution to pour hot water down drain line but don't know where line is or how to locate it?? HELP
  • 77 Answers
It sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Posted on Jul 28, 2009
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
I have a Kenmore side by side Model No. 363.9565522. Noticed water dripping out of front of freezer onto floor - this has happened periodically over the lifetime of the side by side. Slid bottom freezer...
The drain heater goes into the drain,not outside it.
You need a longer drain probe to push all the way through the drain.
Look underneath for a kink in the drain tube.
Feb 06, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 25, 2009 | Magic Chef Refrigerators
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Leak From Freezer
you have a clogged evap drain, you need to take the back panell off the freezer and pour boiling water down the drain port until it flows freely
Jun 13, 2008 | Maytag MZD2768G Side by Side Refrigerator
SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Feb 17, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Ice build up in freezer
Sounds like a defrost problem... need to pull back panel off in freezer and see if u have thick frost build up indicating... heaters, or defrost themostate bad.. could not bring up your model # SO dont know if maybe bad defrost timmer or if you have adaptive defrost control which could also be bad.
Aug 19, 2007 | Frigidaire PHSC39EESS Stainless Steel Side...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
262 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
