Question about Linksys WRT54GC Wireless Router
Linksys WRT54 GC failed auto port forwarding
Linksys WRT54 GC wireless router failed auto port forwarding with Panasonic IP Cam C131.
I have enabled UPnP already.
    President:
  • 1,383 Answers
Check in your pana sonic ipadreses then test in your network can you able ping of ip of cam?
If you can get ping and if you save ip forwarding port 80 to cam ip then check in camera that the settings of "access via interent is enabled" then you cana cces it with cam ip with 80 http port.
Posted on Jul 27, 2009
Linksys wrt160nl wireless router causing e-mail issues
Hmm... That sounds like a port forwarding issue. I take it that you using a POP3 e-mail client since you said your ISP e-mail server sends you your messages? I would suggest that you open up your linksys configuration (the webpage for the settings), click on the Applications & Gaming tab and Single Port Forwarding sub tab. Then, for the first row, select POP3 as Application Name, and your computer's IP Address as To IP Address, enabled it, and click save settings at the bottom. This should hopefully make it work.
Feb 23, 2010 | Linksys Wireless-G WRT54G Router
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Portforwarding on Linksys WAG200G wireless modem/router
Bind the IP address to that port UDP or TCP (or both..your preference) #5060 in the forwarding section of your router. check the box to enable it. Click APPLY or OK or NEXT...wait for changes.
Mar 10, 2009 | Linksys WAG200G Router
Need to open ports 3724/6112
You need to login to the router, go to the applications and gaming tab and then enter the following information into the first two empty lines on the list of ports to forward:
WOW1 / 3724 / 3724 / Both / (your IP address) / Enable
WOW1 / 6112 / 6112 / Both / (your IP address) / Enable
Click on "Save Settings."
You'll need to make your IP address static on your PC for this to work. Since the WRT54GS doesn't allow DHCP address reservations, you'll have to do this manually in your network setup on the PC.
Reply back with your operating system version if you need help with this.
Dec 30, 2008 | Linksys Wireless-G WRT54G Router
Port Fowarding for my Logitech Webcam
Do you know how to do portforwarding in general?
Have a look at the manual - page 21. You can also find it here: ftp://ftp.linksys.com/downloads/NA/userguide/WRT310N_V10_UG_B-WEB.pdf
You should give your computer a static IP address (or enable static DHCP), otherwise the forwarding will fail if DHCP assings a different address to your computer.
Important is that you have two entries, one for port 8888 /TCP and a second one for port 8081 /Both.
If this helped, please come back and leave a comment, to help others with the same problem.
Dec 27, 2008 | Linksys Wireless-G Broadband Router
LINKYSYS HOOK UP
connect ethernet cable of your computer lan card to ports on linksys router ethernet port.
then acee in browser tis link
http://192.168.1.1
then username is admin pasword also admin.if not login then try username blank and pasword is admin
then set dynamic ip adreses enable .asl oset in your tcp /ip properties in lancard.set it to obtained dynamic ip aderss auto.aslo make sure in link sys that dns also automatic geting from isp.
thatys it.
u get INTERNET NOW FROM YOUR ISP.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Port fowarding and remote desktop
Port forwarding is not the only thing that you have to enable to access your home network. Firstly do you just want to access your router from the outside? If that is the case enable remote login via the administration tab.
If you want to login to your computer from the outside then you must first enable remote desktop and enable port forwarding on your router.
You enable port forwarding for port 3389 which is the remote desktop port. So start port is 3389 and end port is 3389 after that set a static IP on your computer that you want to access.
You can enable remote desktop by following the directions below at the link '
http://www.microsoft.com/windowsxp/using/mobility/getstarted/enableremote.mspx
After doing this. What you do is go to the status tab of your router. Look at the IP there.
On the remote computer lauch remote desktop and enter that IP then click connect. IT will then ask you for the username and password of the computer behind the router that you want to login to. After that you should be able to get in.
If you need any clarifications regarding this you may message me and id be glad to help.
Oct 06, 2008 | Linksys Wireless-N WRT150N Router
Port Forwarding
at the time of portforwarding in that you have to give the port number of the device which ip address you put in means if ip cam is there you give the port number for that example 90 you give then you have to give the device.
Jul 24, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54GC Wireless Router Logo
360 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
