Question about Troy Bilt Tb70ss Gas Trimmer
Lawn Trimmer wont reach full revs.
Hi.I have a STIHL 45S lawn trimmer. It starts easy, idles very well and runs well at 1/2 maximum revs. but dies at any more than 1/2 revs. I have replaced the plug, air cleaner filter and put in clean new fuel. Also adjusted the idle and mixture all to no avail. Can you help please ?
Many thanks,
Jim
  • 162 Answers
You might want to check the magnito for rust build up.
it also wouldn't hurt to check the float or maybe even the valves.
since you adjusted the idle and mixture ur probly gonna have to adjust them again to get them back where they should be especially if rust build up on the magnito is the cause of your problem.
it wouldn't hurt to check the fuel filter either.
Posted on Jul 27, 2009
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
STIHL ENGINE REPAIR PROCEDURE FOR ENGINE -HARD TO START & RUNS POORE
Start with adjusting the high and low side adjustment out 1 full turn, then adjust the idle.
Aug 24, 2014 | Stihl String Trimmer Brushcutter Service...
How do you adjust a Stihl weedeater carburetor?
Oiless fuel ruins your compression. The trimmer should crank anywhere above 50 psi. A good place to start with the jets is 3/4 to 1 out. You may have damaged the new jets by srewing them all the way in. These small jets are often needle thin and can be damaged when bottomed out.
Jul 29, 2014 | Stihl Garden
I have a brand new easy start stihl 50 whipper snipper it came already fuelled it kicked over then died and now wont start or kicks and dies any thoughts
Try turning the choke off after it tries to start. This is a first for me. I have never ever heard of any type of yard implement, chain saw, mower, weed trimmer, etc that came brand new with fuel( gas mixture) in it or in the package. The fuel mixture for this trimmer I beleive is 50:1. Is that correct? This means that for one gallon of gas, 2,56 ounces of two cycle oil is added to the gas.
May 17, 2014 | Garden
I have a new Stihl FS90R Trimmer...Idles fine but dies when given gas to rev up. Tried to adjust the carb out. Did not help. I have two of these.Changed the carbs and the same thing happened. The same carb...
My nephew had a problem with his Stihl FS55R trimmer, sez it would run on high for a few then quit. Sez it restarts easy and runs on idle with no problem. I pulled carb & found fuel screen full of fine contaminant. This is the screen you see when you drop the bottom pan of the carb. (single screw does it). Reassembled and the trimmer runs on high speed w/o problems. If your primer bulb doesn't pop right back up when you punch it down, it means that the fuel can't get past that screen....
Nov 07, 2009 | Garden
Stihl line trimmer FS46 Runs good at full throtle
the smallest piece of trash will cause you the biggest problems. try blowing the carb out . i think it has a pre set idle on it.
Sep 18, 2009 | Garden
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
Stihl FS85 Stalls when warm and gas is given will still idle
Make sure the carb settings are correct. Screw both tuning screws all the way in and then turn ot anticlockwise the following settings H 3/4 of a turn, L 1 full turn. (this is set to the standard setting)
Jul 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Lawn trimmer runs but won't rev
You need to clean the carburetor. Remove & disassemble. Use a Den Tek Brush,
(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean small portals in carb. Spray carb. with carb. cleaner. make sure the small screen in carb. is free of debris. Reassemble and start. If this doesn't work, buy a carb.kit and replace the needle valve, gasket(s), small screen, & diaphragm.
Jim
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 31cc lawn trimmer carb adjustment
As with all 2 strokes if you have compression and a reasonable spark, you only need fresh fuel with correct oil ratio) and they must go !(as long as you haven't fiddled first and all gaskets are sealing) I start mine by(1) pumping the primer till it is firm,(2) full choke,(3) pull till it kicks ONCE,(4) half choke, pull till it runs,allow to warm up and(5) switch to run (you may need to apply a bit of throttle while pulling as in (4)(or give it a few more pumps if it dies) If all is ok, check that when properly warmed up there is a smooth transition from idle to full revs, if it hesitates it may need the LOW SPEED mixture leaning (clockwise) SLIGHTLY.If it dies the LOW SPEED mixture may need richening(anti-clockwise)(adjust 1/8 turn at a time) Make sure that motor is just peaking at full revs and is on the RICH side of peaking (HIGH SPEED mixture)(this will avoid seizing it Adjust both till it revs cleanly and is JUST rich at full, and idleing nicely and it should start without too much trouble.(If you have fiddled and are lost,-about 2 1/2 turns out from closed on both needles should get you started)
Nov 23, 2008 | Garden
Troy Bilt Tb70ss Gas Trimmer Logo
610 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
