Question about HP OfficeJet V40 All-In-One InkJet Printer
I've had printer for about 3 yrs. Printer keeps
I've had printer for about 3 yrs. Printer keeps jamming now. Also, sometimes have difficult loading paper as it seems like it catches.
  • 744 Answers
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..
or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Posted on Jul 27, 2009
I keep getting paper jam and load letter paper on my C544dn but yther eis no paper jam and there is a good amount of paper in the printer.
Take a look DEEP inside your printer. Sometimes all it takes is a tiny piece of paper to indicate a jam. Remove your printer cartridge(s), pull out your paper tray, open covers, etc. It is in there somewhere.
Nov 29, 2017 | The Office Equipment & Supplies
Epson stylus sx405 will not load paper
Inspect the rollers that take the paper in. If none of them appear out of place or damaged, it may be that they need cleaning. I've had some success cleaning printer rollers with methylated spirits, but any dust cleaner should work.
Oct 01, 2012 | Computers & Internet
Error 5100 what do i do???
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the print head and cartridges.
This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and print head are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've n
Sep 08, 2011 | Office Equipment & Supplies
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
I have a Samsung CLX6210FX. I get this error Paper Jam 2 Check Inside. I check the paper tray and the toner door but could not find where the paper jam is. Please help
This can be very difficult to find especially if they are small pieces. If you remove the toner cartridge and with a flashlight look all around for any evidence of paper. Also check thoroughly all the doors that will open and all around the rollers. Lastly and this is difficult is the fuser in the very back of the printer. These rollers are extremely hot and sometimes when the fuser goes bad, it will keep the paper in the fuser causing the jam. On the menu you will probably see error codes as well. Hope this helps.
Mar 19, 2011 | Samsung CLX-6210FX Laser Printer
Hi, "ALARM" appear on my
Hi Good day!! Maybe you have a paper jam that cause your printer to alarm.
To clear a rear-feed paper jam:
1. Turn off printer
2. Turn platen knob to back paper out of printer. Remove any ripped pieces of paper.
3. Reload paper, turn printer back on and press FF/LOAD button.
If your paper keeps jamming the chances are excellent that you have bits of paper stuck in the paper in the paper path. To eliminate this problem:
1. Turn off printer.
2. Use platen knob to back paper out of printer.
3. Remove the paper separator.
Thank you for using fixYa
Don't forget to vote thanks!!
Nov 03, 2010 | Oki Electric Industry MICROLINE 791 Matrix...
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
I have a rp-300 which just stopped printing its approx. 3 yrs old
first remove ink cartridge then check there is not any paper jam also check in back side of printer for paper jam.
then try if again problems then reset your printer to factory defaults.
Jan 05, 2009 | Partner Tech PARTNER THERMAL RECEIPT...
HP D155xi - Error Message: Clear Paper Jam (when there is none)
Have an HP office jet d155xl printer and every time I put it on, it takes sometime to warm up then the "scanner failure" pops out on LCD with instructions to put printer off and on again. Same thing happens all over again.
Oct 18, 2007 | HP OfficeJet D155xi All-In-One InkJet...
HP OfficeJet V40 All-In-One InkJet Printer Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
