Yamaha keyboard psr 9000
Hi i wonder if there is anyway i can get something to connect the 50pin scsi
to a usb,somesort of adaptor or anything so that i can use a flash drive for storage hope this makes sense as i am a 67yr old newbie
regards terry
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
Hi My yamaha PSR S500 keyboard is not turning on! I bought a new adaptor but it still wont come on
Check that your adapter is a 12VDC with a current rating of at least 1 amp (1000ma) AND that the center pin of the connector is the POSITIVE.
Feb 07, 2011 | Yamaha PSR-S500 Digital Keyboard
I want to retrieve data from an old 50-pin hd from my old mac. Anybody got a solution?
There are two ways of retrieving data from a SCSI hard drive.
1. Connect the SCSI hard drive to a different SCSI connector on the same data cable, make sure this hard drive has a different SCSI ID from the first hard drive or other SCSI devices in your system. When you boot up your MAC you should see the second SCSI hard drive, You can then copy off your data or remove the redundant files and keep the old hard drive in your system as a 2nd hard drive.
2. Connect the old SCSI hard drive to a SCSI USB hard drive adapter. Then connect it to the USB port on the MAC and you should see this as an external hard drive.
Jun 14, 2010 | Ricoh 2GB Printer Drive (SCSI-50PIN)...
SCSI Hard drives
i think you have two connections to SCSI drives not one to ide and one to scsi. anyway, if you have a SCSI controller card, you only need to connect do SCSI drives. only.
May 06, 2010 | Computers & Internet
I need to replace my floppy drive on a yamaha psr 9000 keyboard
Why.. get a USB floppy.. if you go inside a PC and pull a wrong wire your PC will be toast. Get a USB floppy. Why are you using floppies anyway? Get a USB stick for $8, way less then a replacement floppy and much safer.
Jul 16, 2009 | Computers & Internet
I need for :yamaha keeboard psr 9000 :danish manual
hej I asked my lokal store. thank ouy for answer. best regards poulc
Jun 24, 2009 | Yamaha Portable Keyboard
Yamaha PSR-280 : AC power instead of DC power
An answer, but likely not a solution. I believe all Yamaha PSR series keyboards use the same 12 VDC adaptor, so I looked at the electrical schematic for another model I have. There seems to be no fuse on the power input. There are two components shown on the positive and negative wires off the power socket, but the symbols do not look like anything I have seen for fuses - they may be resistors. Power goes directly to a 5 VDC voltage regulator, which powers all of the solid state componenents. Too much voltage of the wrong type could have easily ruined many of the sensitive components.
Your only hope is to check the power socket area for the possibility of having fuses. My drawing shows the power socket, voltage regulator, and audio power amplifier being on one circuit board. That may not actually be the way it is in your model.
(your English is fine)
Feb 23, 2009 | Yamaha Portable Keyboard with 61...
How do i connect a "fujitsu 4750 scanner to my PC.
my pc does not have a 50pin connector. so i need (i Guess) a converter that will go from the 50 pin to a usb on my pc?
thanks.
May 28, 2008 | Kodak Digital Science 3520DP Path-Through...
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
