Question about Refrigerators
It appears that the water is coming from the coils in the freezer section. I collects at the bottom of the freezer. When the door is opened, it melts and runs out.
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 27, 2009
HMG1947 with ice maker. Intermittent problem getting worse! I am getting water on the inside bottom, which will leak out onto the kitchen floor if I don't catch it with paper towels under the bottom...
Is the freezer section cooling properly. If yes, then problem is drain hole blocked in freezer section.There is a water drain hole, which runs to the drain line.But if the drain hole is got clogged by ice, then water will leak from other end and you get water in bottom drawer.-------- try manual defrost procedure.----------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check, do you notice the same problem, if yes then defrost assembly board is faulty.But in most cases defrost reset procedure helps.----------- Thanks.Helpmech.
Sep 16, 2011 | Admiral Refrigerators
Water in the bottom of the freezer compartment, collects and freezes ,fills the bottom with 1/2 of ice. continues and runs out on the floor. LG LFX25975 Where is the water coming from? Doors and Drawer...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | LG LFX25975SW (247 cu ft) Bottom Freezer...
Bottom of the freezer keeps filling up with water and freezing solid. eventually leaks thru the door onto the floor. It takes 3 to 4 weeks for it to form thick enough to eventually leak thru the door on to...
If the drain is clogged with Ice or ? it overflows into the ref.
Leo Ponder
imufo2
Jul 27, 2011 | GE GSS25JF Side by Side Refrigerator
Water is collecting on the top shelf & in the bottom of the refrigerator. Water is clear. Water at bottom will partially freeze. Cleaned the coils & made sure all vents were unblocked. Problem...
if you have water leaking down from the freezer into the fridge you have a blocked drain in the freezer,if you pulled off the back inside wall of the freezer and melted the ice off of the coil you should have noticed that the water wasn't draining down the drain hole under the coil.pull off the back inside wall of the freezer,look under the coil and you'll see a drain hole,when the freezer defrosts the ice melts and goes into the drain hole and down into the pan at the bottom of the fridge where the compressor is and it evaporates,your drain is blocked and the water is draining into the fridge section.unplug it,melt out any ice with a hair dryer,now you have to clear the drain line,i use a steemer to do this,it blows steem down into the drain and cleans it out in no time but if you don't have a steemer you need something that will push air down into the hole like a turkey baster or even a shop vac,pull off the hose and stick it into the other hole and then you can blow through the drain line with it,when you think the line is clear pour hot water into the hole,if it drains through your done,if not keep hitting it,also if you open the fridge door and with the hair dryer heat up the middle ceiling in the back,that's also part of the drain,in the middle of the ceiling and back wall where they meet,heat it up for around 5 minutes and then try the water,it will clear out,it could take around an hour or so to do it.
Jul 08, 2011 | Kenmore Top Freezer Refrigerator
I have ice building up in the bottom of the freezer even with the ice maker off. Where is the water coming from and what is the fix? I can see a slight trail of ice down the back behind the ice maker and...
From what you described the defrost drain trough is frozen up. The drain tube or the opening in the drain trough is stopped up with some sort of debris and is frozen over.
Each time the freezer goes into a defrost cycle it melts the ice on the coils and the water has no place to go. The result is that water will leak into the freezer compartment, collect on the floor of the freezer and freeze solid.
Mar 20, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Refrigerator isn't cold enough, but the freezer is fine. Model number is PSS26MSWASS, Serial number is GM439772, I turned up the temp for the Refrigerator, but its not that cold.
This problem is related to defrost.The defrost cycle is not running as it should be. The other possibility can be ice blockage in the ventilations.The defrost is not working,.The evaporator coil in the inner section of freezer is got blocked by ice .
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.
Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer works but no cooling in fridge, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets
collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main defrost board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer works but fridge section not getting cold..
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Mar 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
On the kenmore 363.59522996 side by side the freezer is working good but the fridge will not cool and looking for the cause??
Feb 25, 2011 | Kenmore 53642 / 53644 Side by Side...
Fridge is not cooling well. Freezer is fine
Feb 25, 2011 | Frigidaire FRT21P5A Top Freezer...
Over the past couple of weeks, my Side-By-Side Refrigerator freezer has not been running properly. It thaws out for a day or two, then it starts freezing again for a couple more days.
The defrost is not working.This happens due to the evaporator coil in the inner section of freezer is got blocked by ice .--------
Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer thaws after couple of days.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Feb 21, 2011 | Amana ASD2625K Side by Side Refrigerator
The freezer keeps freezing the coil in the back of the freezer how do I put it on defrost
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Take care....
Aug 15, 2010 | Roper Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
