Question about Garden
How do I replace the recoil spring on an echo string trimmer? My start rope broke, and when I disassembled it to replace the rope, the spring came out of its housing. I have been unsuccessful in getting the spring re-coiled neatly and back in its housing.
#1 Taper
  • 1040 Answers
SOURCE: cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Posted on Jun 07, 2009
  • 279 Answers
SOURCE: broken rop on weedeater gas trimmer
There is a spring under the starter spool, the one with the rope on it, leave the spring ALONE, Just take the spool and replace the rope as it is. You take the spool off, put the new rope on the spool, place the spool onto the spring and by holding one end of the rope straight up in one of the slots on the spool, go as many times as you can. When you have it as tight as it can go, hold your thumb down on the spool. Insert the rope through the hole available, grab the rope on the other side of the hole, (outside the casing). Hold the rope and S-L-O-W-L-Y allow the rope to retract. If it finishes before the rope runs out, pull on the rope and install the handle. If it tries to go beyond, hold the rope and install the handle there. Hope you have luck. Remember, leave the spring alone...Lee
Posted on Aug 03, 2009
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
  • 27 Answers
SOURCE: how to put recoil spring
The recoil housing is held on by four screws around the housing on the corners, the pulley is held to the housing by one screw, all tension needs to relieved from the spring before removing the pulley. you can either cut the rope if you are replacing it, or you can pull some of the rope out, lining up the notch in the pulley with the outlet hole, catch the pulley and hold it from rewinding, and using the slack in the rope pull a section back in and up through the notch, the pulley can now unwind its tension without winding up the rope. Now remove the pulley, it should leave the spring in the housing. If the spring is very rusty it should be replaced, if you've sprung the spring out and have a mess, be prepared for a little fight, you can try hooking the outside of the spring in its tab in the housing and while forcibly holding that in place begin coiling the spring back in place, or try gathering the spring into a large coil and holding the coil with a pair of pliers begin shrinking the coil's diameter by winding it up from the center, last resort and the one I'd recommend if you're looking at a rusty spring, get a new one from an Echo dealer, it comes pre-wound and a nifty retaining clip, it simply slides into place in the housing, and as it goes into place the ring will pop loose. Now for the rope. Install the rope by putting the new piece in the spool and tying it off, thread the other end through the housing from the inside out, and put it into the handle and tie it off on that end, now place the spool into the housing being sure to engage the spring lightly, now install the screw so the spool doesn't come out, pull the slack rope up through the notch in the pulley and begin winding the pulley in the direction it turns when the rope is normally extended, after about 4 turns drop the rope out of the notch and let the pulley wind up the rope, if you have slack repeat a couple turns until there is no slack
Posted on Jul 04, 2010
rycgl
  • 1545 Answers
SOURCE: I am looking for a
Go to www.searspartsdirect.com and put in your model info and they will provide you with a download or this will take you directly to the model with diagrams that you need:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358.796121/0247/1503820?pathTaken=
They sell parts on this site or you can probably order them online and/or go to their outlet and pick them up.
Please vote on this solution.
Posted on Sep 06, 2010
Recoil starter pulley not retracting starter string. How do I replace it?
there is a spring that recoils the rope inside .not a hard task but rather tricky with the spring .good luck
Sep 09, 2016 | Garden
Replacing starter cord on stihl fs 70 R trimmer
Go to you tube. On top line repair starter rope on --------
Jul 18, 2016 | Stihl Garden
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
Pull rope will not retract on a rlt30cet
Pull recoil and remove screw holding the string pulley. There's a spring behind it. Find where it hooks to the housing bend it to latch. This is what broke loose. Now wind it all into the designated spot. Attach string pulley and CAREFULLY put back together. Finally wind up insert rope and let it retract. This is a very difficult and frustrating job.
Feb 28, 2013 | Ryobi Garden
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
On my echo weed trimmer the rope broke on the starter. i took it off and the spring came out. how do you reconnect all the workings?
Recoil starters can be very dangerous when coming Apart!!, And During Reassembly!! Please do not attempt unless you are a qualified and certified Echo technician!
The spring of the recoil is what pulls your rope back in, It is of high energy and can harm you during Assembly, if you fail on any one detail. The most common injury is to the eyes! Use proper eye safety when performing repairs on recoil starters!
Re assembly process as follows,,
For parts info, go to http://www.powermowersales.com
Jun 11, 2011 | Garden
The starter string does not retract after being pulled on my Echo weed trimmer
spring probably broke for recoil,will have to pull the 4 screws holding it on and and pull recoil off
you might get lucky as you loosen the bolts it might retract, if it does it is dirty inside and possible nylon guides wore causing it to bind. otherwise spring prob broke inside
Apr 03, 2011 | Echo Garden
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Aug 27, 2010 | Poulan Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Cannot get my trimmer started.
Jim
Jun 07, 2009 | Echo Garden
Garden Logo
1,108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
