Question about Intel Motherboard
AFTER BIOS UPDATE PROBLEM
AFTER UPDATE MY INTEL -845 SERIES MOTHERBOARD BIOS OFTEN THE USB DEVICE ARE BEING DISABLE.TO SOLVE THIS PROBLEM I HAVE TO DO RESET THE BIOS AND ENABLE THE USB FROM THE BIOS SETUP .CAN ANY ONE GAVE ME A PERMANENT SOLUTION TO REMOVE THIS PROBLEM.PLEASE MAIL ME @ amzad_shohel2000@yahoo.com.
    Problem Solver:
  • 27 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
24
Posted on Aug 29, 2009
    President:
  • 1,383 Answers
Change your cmos cell . and also set jumper settings in 2-3 position for sometimes then again put jumpewr in its original position 1-2
Also change cmos cell .
Thanks for using fixya.
Please rate solution if it helps.
Posted on Jul 27, 2009
  • 70 Answers
Enable the USB from bios setup is the permanent solution. if you battery is not low.
Usb device not recognize
Hello visit intel here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
And install the missing mainboard drivers.
Try also to enter the bios function, and look for the usb function is maybe set to off.
Remember to save your work when leaving bios.
Run also windows update.
Good luck
Aug 05, 2013 | Intel DG31PR Motherboard
I need update new BIOS for Intel 845 AGPSet BIOS for 8IDX F7 AWARD BIOS
You can download the motherboarddrivers and BIOS updates from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : -http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Nov 21, 2010 | Intel Gigabyte GA-8IDX 845 AGPset P4...
I have Intel 845 series motherboard & I want to format my PC but when I put xp cd inside & restarts & press enter the boot doesn't start now how could i format ?
You have to change the BIOS settings to boot from your CD drive. It must have been set to boot from harddisk.
To do this you have to change the primary boot device from Harddisk to CD drive. When you restart your computer press DEL or F12 or TAB or F1(any one...Depends on your BIOS see manual or try all) to bring bios. In bios go to boot device priority and set the CD drive to boot first.
Restart your computer, it will boot from CD drive and XP setup will start.
Hope this will help...cheers:)
Sep 25, 2010 | Intel 845GE Motherboard
Intel 845 no display
hi unplug ram then power on if come ram beep then update bios recovery system or ubplug bios ic and update whit programer i have bios backup in binary file
thanxxxxx
zaheer118@hotmail.com
Jul 06, 2010 | Intel D845GVSR Motherboard
Hello, I have updated BIOS of Intel 845 GVSR board. But after the successful update USB is not displayed in BIOS hence no USB device is getting recognized. Please help.
Had exactly the same problem. This process fixed it for me:
http://www.intel.com/cd/channel/reseller/asmo-na/eng/tech_reference/box_processors/int_inst_info/factory_notes_all/203939.htm
  1. Shut down the computer safely and remove the chassis cover.
  2. Move the BIOS Configuration jumper to the Maintenance position. (Refer to the Quick Reference Guide or Product Guide for the location of this jumper.)
  3. Power on the computer and enter BIOS Setup (press F2 during boot).
  4. Go to the Advanced > USB Configuration menu.
  5. Enable the USB Function.
  6. Go to the Exit menu and select Save Custom Defaults.
  7. Save and exit the BIOS setup.
  8. Turn off the computer.
  9. Move the BIOS Configuration jumper back to the normal mode position.
  10. Power on the computer and enter the BIOS Setup again to verify that the Advanced > USB Configuration menu is now back to normal.
Jan 06, 2010 | Intel Motherboard
I have 845 mother board of intel. when i boot my computer, it shows f1 for bios entry. when i enter f1, it goes inside bios but after that my keyboard will not work. please help me.
its problem bios not configure properly reset mother board jumpure 1-2 normal 2-3 reset again position 1-2 machin is on press F2 set up bios your choice configure before unpluged your hard drive
Nov 21, 2009 | Intel Motherboard
Intel 845 GVSR Display problem
did you used the correct bios update, because if you used the wrong update you will encounter these problems, your motherboard has a built in vga and no vga expansion slots only 3 pci, the only way to solve these is if you can find a pci video card which is sometimes hard to find, or just revert back to your old bios version then maybe your display will comeback
Oct 22, 2009 | Intel D845GVSR Motherboard
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Apr 09, 2008 | Intel D845GVSR Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
USB2.0 to work
In the CMOS setup, on the Advanced tab, USB Configuration, enable "High-speed USB", according to this page. The instructions there may not be the same as yours, as Gigabyte may be using a different BIOS. On this page is the latest Intel INF Update Utility for your Intel 845 chipset.
It is also possible that your motherboard does not support USB 2.0. The manual I saw was suspiciously quiet about it.
Dec 06, 2007 | Gigabyte GA-8IRX Motherboard
Intel Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
