Question about Jenn-Air JSD2789GES Side by Side Refrigerator
I JUST INSTALLEDAN ICE DOOR TO A SIDE JENN-AIR REFRIDGERATOR MODEL NBR JSD2789HES. THE DOOR WILL NOT OPEN TO DISPENSE THE ICE. IS THERE A SWITCH THAT NEEDS TO BE REPLACED OR DO I NEED A REPAIR PERSON?? THE PART NBRL I REPLACED WAS PURCHASED FROM EASY APPLIANCE PARTS AND THE PART NBR WAS WPL 61005883. HOW MANY $10'S WILL IT TAKE TO GET AN ANSWER??
  • Thebaptist Jul 27, 2009
    Everything said on the story is true but the bracket that moves the ice door. I did not take the bracket off. All I did was attached the ice door. how do i know if the bracket is set properly? Is there a picture available for me to observe to see if mine is assembled properly? I really do not want to call in a repair person to do a simple thing.
    I did respond earlier but when I went back and took the system apart I did find that I did not reassemble the bracket over the solenoid. Thanks for causing me to "think". I will be using this site more often to help me since all of my warrenties have run out.
    Be blessed
    Thebaptist
  • Jenn-Air Master
  • 19,396 Answers
There is a solenoid, and a connector that can cause the problem.
Check first that is not an installation problem. Ensure that the bracket that moves the ice door had been re assembled, or the door won't open, and you only hear the solenoid humming when you start the ice dispenser.
I also wanted to quote an interesting story from Partselect website:
Disassembled door dispenser, pretty easy, two torx screws on bottom, two on upper part of unit. Slid unit up slightly, it sets over two studs on the top. Unplugged wire connector, set aside unit. Looked on internet for a replacement part. These folks had the easiest to use web site. Found the part, ordered the part, received it next day, but only ordered the least expensive delivery method, since we are both in Florida it worked out well.
I did not know when I ordered this part I would get it this quickly. Because cold air was pouring out of the hole left by the removal of the ice door, I put wide painters tape over the hole on the inside of the freezer door. This greatly reduced the flow of cold air.
After I received the part, I clipped it in place and reassembled the unit, it did not work. The solenoid that moves the door just hummed like it was jammed. I took it back apart and realized that I did not get the bracket that moves the ice door reattached properly. After I made sure the bracket was properly attached, i reassembled the unit and it worked great.
Posted on Jul 27, 2009
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
Our Jenn-Air JCM22 side by side refrigerator water dispensor allows water condensation to run out from behind the rubber boot that houses the on/off water dispensing press switch. In humid conditions this...
HI,OPEN THE FREEZER COMPARTMENT CHECK IF THE DISP ICE DOOR IS CLOSIN PROPERLY ALSO CHEK THE ICE MAKER FOR WATER LEAK,IF HOT AIR IS FILTERING THRU THE DISPENCER ICE DOOR WILL MAKING THE ICE BUCKET ICE TO MELT AND LEAK WATER,IF YOUR ICE MAKER IS BAD WILL LEAK WATER, IF YOU CAN'T FIND THE PROBLEM GET EXPERIANCES SERV TECH TO DIANOST THE PEOBLEM..
Feb 21, 2011 | Jenn-Air Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
I bought a used Jenn Air french door refrigerator model #JFC2089HES, but water will not dispense nor will it make ice. It's hooked up to a cold water supply under the sink which is working.
It sounds to me like you're going to have to do some serious electrical checking. There are two electrical solenoid water control valves right behind of the fiber cover where your water line connects to the refrigerator. One solenoid valve is for the water dispenser and the other is for the ice maker. They are mounted together, side by side, on the same metal mounting plate. You two sets of terminals on each solenoid. one set on each solenoid should be hot (register line voltage) when tested between the terminal and ground. the other set of terminals connect two the switches in the water dispenser and ice maker. If have someone push the dispenser switch while you have your ear close to the solenoids, you should hear a clicking sound. I have never seen both of the solenoid valves go bad at the same time. I believe you have a power supply problem to the solenoid assembly itself.
Mar 16, 2010 | Jenn-Air JFC2089HE French Door...
My ice and water dispenser sticks. I have to open
The door flap may not be opening and closing completely thereby trapping the ice. There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 13, 2010 | Jenn-Air JSD2789GES Side by Side...
Model JCD2389GEW - ice/water dispenser does not work. Until recently, it did not do anything on any of the settings (water, cube and crushed ice) now it crushes ice on all three settings but the door does...
We have a Jenn Air side by side, model JCD2389GEW. The ice dispensers work, the water does not. This started after I replaced the filter. I've checked and nothing is locked out. When you press the actuator pad to dispense water, you can hear a noise similar to a small pump which I assume is a solenoid attempting to open. Any ideas?
Oct 02, 2009 | Jenn-Air Refrigerators
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Jun 06, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice Dispenser "Flapper" is loose--How does it reattach?
the plastic arms that move the flapper door open and closed are broken. I had this happen to me some months back. You will need to buy a repair kit from your local dealer. Explain what is broken and they can look up their part/kit number. You can't buy just the plastic door. Mine cost about $30 but was worth the price of getting my ice maker dispenser operating again. Very minor mechanics required to open this portion of the mechanism. Mostly some removal of screws and a spring or two. Good luck.
Apr 14, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Jenn Air Side by Side Refridgerator
You could have a layer of solid ice at the bottom of your icetray which is binding everything up. Remove ice tray and any ice from the bottom. Reinstall and be careful of the connection on the back of the ice tray, you may have to turn it a little to get it to mesh correctly. refill and try. Good luck.
Jan 08, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
