Question about HP LaserJet P2015n Printer
Toner light & jam light on
After turning printer on the toner light & jam light comes on and if switch machine off then on sometimes just the jam or no paper warning aslo?
  • rankinoffice Aug 27, 2009
    I have had the same problem before,its the main board on lefthand side of the machine,it needs to be replaced
  • rankinoffice Sep 20, 2009
    main board replaced and sorted problems
  • 4 Answers
Take out Formatter (main board) bake for 8 minutes at 350F,. let cool and put back in.
Put the card face up in a cookie tray and use screws to make sure it doesn't touch the tray.
Works fine
Posted on Oct 27, 2009
I have a Brother MFC 8220 with a nonBrother cartridge and the original Brother drum. No problems printing until today. I tried to send a 4x6 piece of thin card stock through the front manual feed on the...
There are possibly 2 reasons why this is happening.
1. The drum unit may have been damaged in some way but I doubt it. Check fully that all contacts are in the right place at either side of the drum unit. A contact may be slightly bent.
2. Check the Transfer Roller is in its correct position. The transfer roller is the felt type roller that is positioned in the printer under where the drum unit goes. If this has got out of position then that could also cause the faint printing. Check contacts in printer are not bent.
May 19, 2011 | Brother MFC-8220 Fax
I own a ML-2525/XAA and have a blinking light on the right hand side of the unit. It looks like: <--->/(a triangle with an explanation mark inside it.
Per your user manual, here is a list of all the LED status':
Jam (b-error.png)
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error (b-online.png)
Off
  • The machine is off-line.
Green
On
  • The machine is in power saver mode.
  • The machine is on-line and can receive data from the computer.
Blinking
  • When the LED slowly bilnks, the machine is receiving data from the computer.
  • When the LED rapidly blinks, the machine is printing data.
Red
On
  • The cover is opened. Close the cover.
  • There is no paper in the tray. Load paper in the tray.
  • The machine has stopped due to a major error.
  • Your system has some problems. If this problem occurs, contact your service representative.
  • A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
  • A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
  • Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
Replaced the waste toner box.
re check for the toner inserted, be sure that protected plastic remove. shake and insert again.
Apr 15, 2010 | Samsung CLP 315 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Savin 3510 add toner ,new toner in machine
THIS PROBLEM ALSO OCCUR IN RICOH AND GESTETNER/LANIER AS THEY SHARE SIMILAR OPERATING SYSTEM. WHAT YOU CAN DO IS TO CHECK THE TONE HOPPER OUTLET ,SOMETIMES IT IS BLOCKED BY MYLAR COVER WHEN YOU REPLACED THE NEW TONER..YOU JUST TURN THE TONER BOTTLE/TWIST A BIT AND YOU CAN SEE THE TONER WILL COME OUT FROM THE HOPPER OUTLET. IF NOT TRY TO FIX THE MYLAR COVER.
THE SECOND PROBLEM IS BLOCKED TONER INLET IN PCU .YOU HAVE TO TAKE OUT THE PCU & CHECKED THE TONER INLET,SOMETIMES IT IS BLOCKED BY SEAL OR THE JAMMED INLET CLOSURE MECHANISM AND IT CAN BE REPAIRED IF YOU HAD THE EXPERIENCESD SERVICING THE PCU. GOOG LUCK
Mar 15, 2010 | Savin Office Equipment & Supplies
It always says paper jam and it has no paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
if the problem remains, some of the sensor / switches might have become stuck or are out of place, or there is still a small piece of paper or something else inside the machine and its coming up as a paper jam.
The machine would need to be taken apart and cleaned to solve the issue.
Nov 03, 2009 | Dell Photo 964 All-In-One InkJet Printer
I have a paper jam 071-100 and cannot find it. I have no manual and I need help.
alternative :
if the problem remains you will most likely have to take the machine apart to find the paper or unjam one or two of the paper path sensor switches that may have become stuck.
Sep 12, 2009 | Office Equipment & Supplies
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Jun 30, 2009 | Canon NP 7130 Black and White Copier
Cannot print
There is either a paper jam or the printer thinks there is a paper jam, which could be a problem with the door interlock switch or the printer not recognizing the toner cartridge. It could also mean an issue with the formatter card. Open the toner door, remove the cartridge, and take a look inside at the paper-clip like springs which make contact with the metal contacts on the toner cartridge. Sometimes they can get bent on one side or bent down and not make contact with the cartridge. Straighten it out if it looks suspicious and reinsert the cartridge and see if the light goes away. Press in hard on the toner door to make sure the door interlock is working. If the motor turns when you first power on or when you open and close the toner door, the sensors and flags are probably in the right position, so it is probably not a jam issue. If the motor does not turn, then the sensor or flags might be an issue. The most common is the exit center in front of the fuser in the back.
Apr 24, 2007 | HP LaserJet 1100 Printer
HP LaserJet P2015n Printer Logo
375 people viewed this question
Ben Johnson
