Question about Mintek MDP-1815 Portable DVD Player
MDP 1815 DVD player using AV Cable to TV. Audio but no video
I have a TV with 2 sets of RCA jacks (front and back). I often play my camcorder through the TV using AV cables so I know the TV jacks are fine and the cables are fine. But when I play my MDP 1815 DVD player using the same AV Cables to the same TV I get only Audio and NO Video. I have tried two different AV cables and both work with the camcorder so I trust the cables and the TV. Any chance that the jack on this DVD player requires a special AV cable? The DVD player came with a cable, but I am not sure if it is one of the ones that I have.
2 Suggested Answers
ItWillBoK
  • 108 Answers
SOURCE: MDP-1815: can't get video on external TV using AV-Out
The AV is actually the yellow jack.
Just plug that in.
If it don't come up then you have to enable it in display options.
How you do that is click on the center of the laptop screen when the menu appears goto properties and then advanced you will see the settings.
Happy Holiday
Posted on Dec 24, 2008
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Can i hook up cable to mintek player
the answer is yes. Check the sides of the player, you will see a yellow jack space, just like the earphone jack space which is green.
The yellow jack space is called "AV OUT" that where wire will be connected from the player to TV.
The wire you will be using is 3.5mm to RCA Video cord. There is 3.5mm to RCA Audio, so make sure you get 3.5mm to RCA Video cord.
I hope you understand my message.
Good luck.
Apr 16, 2010 | Mintek MDP-1030 Portable DVD Player
I'm looking for a cable from my Mintek MDP-1815 Player 2 tv
That should be a relatively common cable. I would try radio shack, if you have one in your area.
Apr 19, 2009 | Mintek MDP-1815 Portable DVD Player
Just plug that in.
Happy Holiday
Dec 24, 2008 | Mintek MDP-1815 Portable DVD Player
Want to watch thru tv
Hi
Check and see if you have A/V out jacks on the unit. If you do, they will be yellow, red, and white.
They are called RCA jacks, and if you have them, and the TV has the same type of jacks, then you just need the cable that goes in between. The DVD player normally comes with them, but if not, you can purchase them at any Circuit City, or even Walmart.
Jan 14, 2008 | Mintek MDP-1815 Portable DVD Player
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
Mintek MDP-1815 Portable DVD Player Logo
90 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
