Question about E-Machines eMachines Monitor E15T4
E machine monitor and blue flashing power light
I can't get out of safe mode but when given the chance my e machine monitor shuts down and the power light blinks blue. Is it the monitor? I am trying to fix a virus problem but can't get into the system! HELP!!!
5 Suggested Answers
compdoctor20
  • 172 Answers
SOURCE: e machine monitor
Check the settings control panel, power options to make sure the setting is not engage to power saving after "minutes" if it is change to the require time or disable, then apply the settings and exit. if this is not the problem, the other most common problem with these emachines and random and frequent unplanned shutdowns is a the motherboard itself. Contact me for further support on this item
Posted on Sep 15, 2008
rrowe69
  • 6 Answers
SOURCE: monitor turns on then shuts off in seconds.
check your video card connections. make sure that your monitor cable is attached firmly in place.Also make sure the video card is fully pushed into the slot on the motherboard. Sometimes because of heat the card can pop out of the slot. Sometime this is just enough to barely work and then stop.
Posted on Mar 18, 2009
  • 5 Answers
SOURCE: Monitor power light blinks blue but does not power on
if the screen was fryed the fuse would of blew which means there would be no lights at all.. the best thing you can do is plug your screen into another pc to see if anything happens.. if nothing happens then yeah your screen must of messed up somewhere.. but if your screen works on another computer then your graphics card config cant be right somewhere along the line
Posted on Jun 10, 2009
budmrtn
  • 11361 Answers
SOURCE: Started pc in safe mode. Monitor comes on but
Try it on another PC first just to make sure it is not the PC problem, you can also try to set the resolution to 640 x 480 @60 Hz when you are in safe mode, reboot the PC and if it displays OK, then set the resolution to the monitor native resolution which is 1440 x 900 @60Hz.
Posted on Mar 13, 2010
I installed a drawing tablet on my emachines netbook 250, after the installation the setup program asked if i wanted to restart, i said yes. It began shutting down some programs but then nothing happend so...
This blue screen is commonly referred to as a BSOD - Blue Screen of Death. Unfortunately, if your computer is looping a BSOD your options are greatly limited and you will most likely need to do a complete wipe of your computer and start over. Getting your data before this happens though should still be possible! Assuming you've a flash drive or external drive with the necessary space, you'll need to boot your computer into Safe Mode. I'd say there's a decent chance you'll be able to get into Safe Mode without a BSOD just so you can get your files. Note that a lot of things will be disabled in Safe Mode, so chances are you won't be able to do your work in it. To do this, turn your computer off and then back on. Right as your computer turns on, hold down the F8 key. Since every computer is different it's difficult for me to describe what you'll see, but if you see anything related to Safe Mode, you want to select that.
Mar 12, 2011 | eMachines eM250-1915 Netbook
My Acer Aspire x1200 desktop won't turn on. I press the power button, the fans rev and the lights flash blue as normal, then it beenps once and shuts down. It keeps cycling like this, trying to turn itself...
Have you by chance downloaded a new Service Pack for Windows?
Try booting into safe mode and doing a System Restore (if possible), if not try taking out your RAM Module(s) and re-seating them (it). If more than one try re-seating each one separately. One bad module could cause erratic behavior.
Oct 14, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
Computer turns on, no signal to lcd. Hard drive
The blue screen was caused by corrupted drivers or a virus that was corrupting the drivers. Have you tried starting the machine in SAFE mode? To do this press F8 while the computer is starting before Windows loads. You should get a menu with several SAFE mode choices. Select SAFE mode and continue. If the computer works fine at this point, I suggest downloading the following AVGFREE.exe, MALWAREBYTES.exe and SUPERANTISPYWARE.exe. Run these to absolutely eliminate any chance of a virus. Once done go to START, Run and type SFC/scannow. You’ll need to have your original CD’s handy. This will replace any corrupt drivers. Now, what to do if you can’t get into SAFE mode. The question then is anything showing on the screen? If nothing but you can hear the fans but no beep codes I suggest you take the laptop to a reputable repair person or check my website www.micromendllc.com. Good luck.
Mar 01, 2010 | Computers & Internet
Screen comes on ,then shuts down.(light is blue and goes yellow)Resolution reminder comes on.Information says mode is 640x80. The above info came from pushing the menu button on the side and I can see...
Hi
Please try the following, go into safe mode (power on PC repeatedly hit F8 until a menu is presented choose safe mode
Once in safe mode Click the following
Start>Control Panel> System> (Tab) hardware > Device manager
Click on the small + next to display adapters, right click and click on the VGA card and click uninstall, the PC will ask you to restart follow the instructions through and hopefully all will be working
Please can i ask that you leave feedback and vote if this has been useful
Feb 10, 2010 | E-Machines 19" Widescreen Flat Panel TFT...
PC monitor has blue USER MODE box that flashes and cannot get rid of it
The blue screen of death is incredibly frustrating. Windowsmag-glass_10x10.gif gives you an option called Safe Mode for whenever there is an internal Windows problem on your PC that needs to be resolved such as the blue screen of death or the display driver setting resolution is so low that you cannot navigate through Windows to alter the settings to a higher resolution. Safe mode allows the user to fix problems without these problems loading up.
  1. tep 1 Reboot your PC. If you can't restart normally by going to the start up menu, then hold in the power button for a few minutes. If you need to enter safe mode but can restart normally, do so.
  2. Step 2 After the hard drivemag-glass_10x10.gif mounts but BEFORE Windows starts to load, Press the F8 key repeatedly on your keyboard. If you do not get the menu with the safe mode option, then you did not begin tapping F8 soon enough. Try again.
  3. Step 3 There will be a menu that will appear. Select Safe Mode. Once you are in safe mode, you can fix what needs to be fixed without the problems loading up on your machine.
Nov 13, 2009 | LG Flatron L1715S 17" LCD Monitor
Shutdown
Try booting in safe mode (press F8 right at the end of the bios boot screen and select safe mode). If the problem still persists while running in safe mode then you probably have a hardware problem. In this case power down and re-check all of your connections, reseat any add-on cards, check all power cables, etc. If the problem goes away while in safe mode, then your problem is software related. In that case (while in safe mode still) try removing software and/or hardware drivers and rebooting normally to see if the problem goes away.
A fresh re-install of XP is always a good cure on these type of systems as well.
Jul 08, 2009 | HP Compaq d530 SFF PC Desktop
PC shuts down while running Windows
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu, Select Safe-Mode boot
If you can get into safe-mode I would suggest to try doing an online scan, as it sounds like your issue could be related to malware:
www.trendmicro.com/housecall
Let us know
Good luck
Apr 15, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
My monitor shuts down on windows startup and it is only working in safe mode. if i let windows startup normally monitor just goes stand by. i have ati radeon x1300/x1550 series driver installed and if i...
these cards do require that additional power be given to them from the power supply. Have you connected the card to your PC power supply via the 3 pin connector and power connector.
Also uninstall the driver via safe mode and let it redetect in normal mode then install the latest drivers for your card. Download from ati.com
Mar 14, 2009 | Sapphire ATI RADEON X1300XT 512MB...
Screen Keeps turning off after about 1 second. I turn it on and can see the desktop for about a second then the screen shuts itself off.
Have you tried booting into safe mode? This will also provide a safe video mode. During bootup, press the F8 key. Arrow down to "Safe Mode" and press the enter key. If the monitor still does it after this, chances are it is bad.
Mar 10, 2009 | ViewSonic VA902 19" LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
731 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
