Question about Jenn-Air JJW8230D Electric Double Oven
How to patch hold in electric oven?
Our electric oven (old Roper double set in) element died in a dramatic way (lots of zzzz's sizzle and bright orange lights while we ran for the circuit breaker). It's replaced now, but it burned a small hole in the bottom of the oven!
Other than covering the hole with aluminum foil, how might we patch it? (We can use the bottom oven for baking, but only this one has a broiler element.
  • mbrio Jul 27, 2009
    sorry for the typo -- that's a hole in the oven
    Thank you for your speedy reply! My search for epoxies suggest a max. temp. of 200 or 300 degrees. A search for titanium epoxy said,
    "Excellent temperature resistance (350°F)"
    Is there a source for epoxy and titanium putty that can take being close to the oven heating element -- maybe more like 600 degrees?
  • 3,600 Answers
Use some high heat two part epoxy let it set up just a little and then plug the hole. you can use titainum putty at a bering supply store but it's expensive but is a good fix.
Posted on Jul 27, 2009
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Only bottom of the electric double wall oven works . lts a 1969 G.E.
If you can, test for power to the element in the top oven. If there is power coming to the element, it could be that the element is bad and can be replaced. If there is now power coming to the top oven there could be a more serious issue in a 40 year old oven
Nov 30, 2009 | GE JTP27 Electric Double Oven
Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Aug 31, 2009 | Frigidaire 30 in. Electric Double...
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
1,458 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
