Question about Electronics - Others
Power surge on usb port - Electronics - Others
    Problem Solver:
  • 4 Answers
Power surge problem is not a software issue, rather its a hardware problem..
all u need to replace main usb controll chip on the mainboard .. usually its common in dell's pc(s)..
Posted on Jul 29, 2009
Lenovo usb port replicator problems power surge
You probably have a fried board in the port rep. after a power surge. Fixing it will probably cost you more that getting a replacement. Other option is to find a used one.
Jan 20, 2012 | Lenovo ThinkPad USB Port Replicator with...
I am getting error power surge on hub port in windows xp pro
your usb hub is exceeding the power limit or you are attaching a device that is extracting more more , use a USB 2.0 port HUB with a power adapter if you are attaching more devices on hub
Sep 24, 2009 | Computers & Internet
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port message
unplug your mp3 player immediately!! it will fry your mp3 player if you leave it plugged in!! try adjusting the player's settings and seeing if there is somewhere to switch it from '1000mah' to '500mah' or lower. try that. if it still gives the error try a different usb port.
May 26, 2009 | Microsoft Windows XP Home Edition
Nothing hooked up to usb ports but computer tells me power surge
umm, usually you can't. your board is probably feeding too much current/voltage to the usb ports or someone shoved a paperclip into the port and shorted it out (frying the power supply to the usb ports) in any case, you will probably need a new motherboard or power supply.
May 26, 2009 | E-Machines T2682 PC Desktop
Usb power surge problem
disable and remove all the usb ports from the device manager then reinstall them else install a fresh OS
May 15, 2009 | E-Machines eMachines Desktop PC
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Electronics - Others Logo
87 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
