SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
SOURCE: toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
