While I was moving, I put my printer without box in the car about 4 days. Then, when I reconnected the printer, it started making weired sounds and printed only spots when i tried to print someting. Now, after trying several times, it prints nothing. I just replaced new cartidege before i moved so I know there was enough toner to print. Help me please.
  • 73 Answers
The toner cartridges may have drawn dampness while sitting in the car.
Try taking the cartridges out, turn them upside down with the opening facing you so as not to spill toner. Shake the toner cartridge from side to side (left to right) to loosen and mix toner inside the cartridges.
Re-install the cartridges and try to printer again.
Let me know if this helps.
Posted on Jul 27, 2009
  • 31 Answers
I dear nex time you transport equipment of any kind ensure you pack them nicely in original packages if you threw them away look for something ideal.
So your problem could be print head is not in position :1.check print head drive belt it could be off the the drive gear.2.check also the shaft is in right position.
No fuse flashes on the display and the fuse box makes a clicking noise
Clicking noise is a relay. Not a fuse. You will have to find which relay is bad out out.
Oct 30, 2015 | 2011 Dodge Grand Caravan
How do I replace the Hayward sp1070
Good Day, this is John the Hayward tech. I have attached a link to the SP-1070 skimmer. The weir is replaced by removing a screw from inside the front of the throat of the skimmer. This removes the plate the weir is attached to. You can also just pop out the weir without removing this plate by gently bending the plate at one end and removing the weir pins from the plate. http://www.hayward-pool.com/pdf/manuals/Automatic-Surface-Skimmer-SP1071-SP1070.pdf
Aug 30, 2014 | Hayward SP1070 SkimMaster Auto Skim Series...
94 jeep grand cherokee, trannys slippg in 1s gear, added lucas stop slip, started next day, drve a few feet and it wont engage.......
Transmission might be fried. One suggestion, did you try putting it in 4WD and trying that? I had a Jeep come in, same thing, wont move, ended up being a blown transfer case. Put it in 4 hi or low, and see if it will go into gear and move. Long shot, but worth a try.
Dec 29, 2013 | 1994 Jeep Grand Cherokee
My 96 dodge ram 1500 4x4 with a 5.2 ran great and
Kind of sounds to me like you have an o2 sensor problem.
Aug 07, 2013 | 1998 Dodge Ram 1500 4WD
I have camry le 2002 recently i notice every morning when the engine is cold i have slow shifting. when put to drive it takes effort by accerelating for 4 mins b4 it picks up and drive normal after about 3...
Sounds much like ****** pump/Tork converter leak down, have you checked the ****** fluid level and condition? better have it checked before you get stuck in traffic.
Aug 29, 2011 | 1989 Ford Bronco
Ghost n car
Sounds like a bad (shorted) headlight relay switch.
test: If it always happens, then unplug the relay switch at the end of your driving day. Put back in the next day. Does the engine start?
The headlight relay (little black box with 4 connectors) is located in the fusebox under the hood. It pulls straight out.
Replace it.
Sep 29, 2009 | 1992 Chevrolet Camaro
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
My mazda engine car over heats and it doesnt move fast enough
ok this sound weired but i bet i am right. ur cadalatic converter is clogged up. be care u can ruin ur engine
Jul 18, 2009 | 1997 Mazda 626
Speaker box wont work. Its hooked correctly to the lanzar amp. Theres little action. It started when we took my speaker box out in order to have space for vacation. Put it back in n after a couple days the...
The quickest way to tell the woofers are good or still hooked up... you need a multimeter set to ohms. test each speaker and make sure you get a reading of 2, 4 or 8 ohms. ifs its a prefab box, probably 4 ohms each but still depends on make. Make sure the speakers have good connection inside and out. Make sure amp wiring is in good condition too.
Jul 12, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
1999 jeep grand cherokee will not start because of alarm
Sounds like the brain quit on you, I would uninstall it or completly disconnect it and have it looked at. Make sure you reconnect the factory wires and start over. Also check the ground for the alarm as it will draw current from what ever wire it can and cause all kinds of things.
May 26, 2009 | 4-Button Remote Start/Keyless Entry with...
42 people viewed this question
jasbo
jasbo
