Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
External Screen issue
I m having a bb8220, i m not getting the external otifications of incoming messages...i have already changed the settings many times
I had the same problem after I dropped my new blackberry. While the phone is on, take out the battery for a hard reset.
Posted on Jul 31, 2009
First back up your handheld then
Go to Settings/Security/General settings then press the blackberry symbol for full menu and " wipe" handheld" .. then restore your handheld from your back up and all should be ok again
Looking for external USB Floppy disk drive for windows 8?
From the issue description, I understand that external floppy drive does not recognize in Windows 8.
I will certainly help you with this issue.
1. What is the make and model of your computer?
2. What is the make and model of your floppy drive?
3. Are you getting any error message?
4. Were there any changes made to the computer prior to the issue?
Please follow the methods.
Method 1:
Run the troubleshooter and check.
a) Press the 'Windows + C' to activate the charms menu or move the mouse pointer to bottom right corner of the screen and you will get the charms menu.
b) Click on 'search' and select 'settings' and type 'Troubleshooting' and select 'troubleshooting'.
c) Click on 'Hardware and Sound' and select 'Hardware and Devices' and click on next to run the troubleshooter.
Method 2:
Please visit the manufacturer website of the device to install the latest drivers and check.
Sep 26, 2014 | SYBA USB Floppy Disk Drive (External) NEC...
HP Pavillion with Vista won't display on external monitor.
Re-boot the laptop. Verify that the "POST" operation comes on during the restart - if not then you have a graphics issue in the laptop.
Feb 13, 2013 | Computers & Internet
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 19, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
My computer was working fie. i closed it for a second and when i opened it again the screen was black. the back light still worked but the screen was blank
Try testing it out through your external ports like the vga, svideo (hdmi if you have one) port to a external monitor, or a tv and see if you get anything there. If you are able to get display to a tv, or external monitor through your external port, then you might have a issue with your screen inverter, or loose connection somehwere between your screen and your laptop base. Secondly if you can't get a display to a tv or external monitor using the external ports, or you get the same display like your screen, then your vga chipset is screwed, and you motherboard will need replacement since the vga chipset is solder onto the motherboard. At this point you can either try to replace the motherboard, (which is going to cost you almost or more then a brand new laptop) or decide to go ahead and get a new laptop.
Feb 01, 2011 | Compaq Presario CQ60-220US PC Laptop
My base model htc touch phone destroys it external sd card
please try to soft reset (restoring it to factory settings.. your device after taking backup of your data, as there might be a virus issue, so soft resetting the device shall solve your issues..
Mar 19, 2010 | HTC S710 Smartphone
Lg Voyager incoming text automatically show up on external screen. how do i turn that off?
In the settings or options section of the texting mode (a soft key feature) you will find something called AUTO VIEW. Open it and make your choice.
Message - settings - TXT msg - auto view on my LG's
Thanks for posting at FixYa.com
Dec 13, 2009 | LG VOYAGER VX10000 Cellular Phone
I need different ringtones on my Nortel 7310
you should already, intrnal is double ring and external is long single ring. you can set sounds from the softkeys below display.
Nov 12, 2009 | Lands Phones
Blue screen of error with memory dump message and Vertical line
try to use an external monitor, plug it on the system and let it work with it for an entire day, it the problem occurs on the external monitor, it can be the video card, but if the problem doesnt happen on external monitor, its the lcd. try also to go to bios, by pressing F2 when the computer turns on and you see the dell screen, it will go to the bis an let it stay there for hours, if the problem happens in bios, video card is indeed bad. you said you have tried the diagnostics? is it by pressing Fn and power button? if the diagnostic looks fine, its a software but you mentioned you have reinstalled the operating sytem already,so focus on the hardware part. i believe your video card might be intel which is integrated or nvidia,for nvidia, lots of issues for it. so better try the external monitor or go to bios.
Sep 26, 2009 | Dell XPS M1210 Notebook
CHANGE SMS TONES ON BLACKBERRY FLIP 8220
On the menu screen, you go to the speaker icon (Profiles) and click on it. From there you will click on Advanced. It should have your current ring selection highlighted already. You will then click the menu button click on Show Ringtones and choose the ring tone you want to use. Hope this helps!
Jun 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Black Screen
If you have a picture on your desktop and nothing on your external,With external screen plugged in check the output set up on display properties,may need to be set up again.
Once the screens are identified you should be able to save these settings and remember to set the correct screen size or you may experience Black screen syndrome were your video picture should be displayed,if in doubt start at the smallest (800x600) and work from there adjusting to suit the individual requirements.
Don't for get to save before reboot then test,
Jun 19, 2008 | Acer Aspire 3000 Notebook
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
151 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
