Question about Canon Office Equipment & Supplies
I have MP150 & cannot find my manual. How do I change ink cartridge?
  • 499 Answers
Hi follow this link and download this pdf file to make ur pc but to maker ur pc able to read it u can download the pdf reader from here http://download.cnet.com/3001-10743_4-10000062.html?spi=8e6ca9a765672935a9e57703b9ca8db8
the printer ink install instruction http://www.downloadtaxi.com/d/1248705341/mp150_esi_us.pdf
Posted on Jul 27, 2009
  • 744 Answers
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..
or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
4 Suggested Answers
SOURCE: canon pixma mp150
With the printer on, just lift up the scanner unit (not lid) and the cartridge will come across to the left side of the printer. Then push down on the cartridge and they should pop out. if the cartridge don't move to the left side of the printer, then there could be something stopping it. Good luck
Posted on Feb 21, 2008
  • 421 Answers
SOURCE: Canon MP150 Flashing E5E5E5........
The E5 error is indeed an error regarding the print cartridges. Are you using original Canon ink. If not then the brand you are using may not be compatible. I would do an eeprom reset and see if that helps. Service manual here, will show you how:
http://www.tradebit.com/filedetail.php/4589462-canon-pixma-mp150-printer-service-manual
Posted on Nov 22, 2008
  • 11800 Answers
SOURCE: Good afternoon, We have a Canon
This is a relatively simple procedure. Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges - they will automatically move out of the way. Now unplug the printer. The pads are now accessible - take them out of the retainers with tweezers or some other pointy tool. To clean them just rinse them with warm water until no ink seeps out.
Now you must reset the waste ink counter:
1. With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. Now release the Power button and the Stop / Reset button, the printer will move into a
service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button 4 times for waste ink counter reset.
5. Turn off the printer (it must be turn off) then turn it on again.
Posted on Jan 06, 2011
Canon pixma MP150 was working normally and today it says that cannot recognize ink cartridge. what can be solutions?
Fix Canon pixma MP150 was working normally and today it says that cannot recognize ink cartridge
May 20, 2010 | Canon Pixma MP500 All-In-One InkJet...
I cant find the manual to canon pixma mp150.
Hi Irene
You solve the problem by replacing the empty ink cartridge.
Most printers (not just Canon) are designed to stop working if an ink cartridge is empty. This is to prevent the nozzles for the empty colour overheating and destroying themselves - the ink passing through acts as the coolant.
Dec 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hello I`am John Farrugia my problem is , errer 5 Thanks. jpmdfar@gmail.com
E5 is the ink cartridge is not installed or not supported ink.In your case one or both ink cartridges are defective.Usually first failing the color cartridge.Change first color if not help change both cartridges.
Oct 23, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My mp150 wont let the paper feed into it & the b & c lights are continually flashing any ideas
The ink cartridges are empty.Replace them or press
consistently button for black copy and button for color copy.This will disable the function of the printer to show ink levels and you will continue printing so long as the ink finally over.
Oct 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a pixma mp150and can't figure out how to change the ink cartridge....where is it/ are they ? How do you know it is empty.....I've misplaced my manual !!
You have to lift up the entire top (scanner unit) to access the ink cartridges.
Here is a link to Canon Support for your printer:
MP150 Printer
Click on the User Guide and/or the Easy Setup links on the "Drivers and Downloads" tab.
Dec 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Nov 21, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Colour Cartridge
hi check your cartridge number are ok , clean the pin points of the cartridge and carridge pins of the printer if not works , try another cartridge if not works than may be carridge faulty , carridge data cable faulty, or logic card of the printer go to your service center or any repairing shop .
Mar 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
35 people viewed this question
old marine
old marine
