Televison & Video Logo
S
Sandra Helm Posted on Jul 31, 2017
I do not know how to find the correct nework for my firestick TV
Hello Fixya team, I need help!
To set up your home theater system with the equipment you mentioned, follow these steps:
  1. Connect the Onkyo receiver to the NEC TV using an HDMI cable. Make sure the HDMI input on the TV is set to the correct input for the Onkyo receiver.
  2. Connect the Panasonic DVD player to the Onkyo receiver using an HDMI cable.
  3. Connect the Firestick Lite to the Onkyo receiver using an HDMI cable.
  4. Connect the Panasonic speakers to the Onkyo receiver using speaker wires. Make sure you connect the speakers to the correct speaker terminals on the receiver, which are usually labeled with the speaker's position (e.g. front left, front right, center, surround left, surround right).
  5. Configure the Onkyo receiver to use the correct input for each device. For example, set the input to "DVD" when you want to watch a movie on the Panasonic DVD player, or set the input to "Firestick" when you want to watch content on the Firestick Lite.
  6. Configure the audio settings on the Onkyo receiver to use the correct audio format for your content. For example, if you are watching a movie with Dolby Digital surround sound, make sure the receiver is set to decode Dolby Digital audio.
  7. Adjust the volume and other audio settings on the Onkyo receiver as needed to optimize the sound quality.
Once you have completed these steps, you should be able to enjoy surround sound audio from your Panasonic speakers through the Onkyo receiver.
How do you program a firestick on an Allegra Television when the tv brand isn't on the list of tv's that they have.
If you used a search feature to find it, it is because you spelled it 'Allerga' instead of Allegra. I edited the question to reflect the correct spelling.
https://www.google.com/search?q=program+a+firestick+on+a+allegra+tv
Switching to another hdmi input
Sounds like the TV doesnt recognize the Firestick as an HDMI source. Or the Firestick isn't getting power. Or the Firestick is broken.
Does the firestick work in the HDMI port the DirectTV is currently in?
My firestick says "Not supported" after saying "searching" --- works great on another tv... I have visio they have samsung?
Contact the TV set maker to see if the firestick is supported by the set. Then you will know if there is something wrong with the set, or it is right and it won't work.
How do I get an amazon fire stick to work on my Panasonic plasma tv model TH-37PX70BA
  1. Plug your Firestick into one of the HDMI ports on your TV. Plug the USB power cable into your Firestick and into the wall or a USB outlet on your TV (if there is one)
  2. Turn on your TV and set the INPUT device to the correct HDMI port. There should be a splash screen or setup screen on your TV at that point.
  3. Using your Firestick remote, navigate to network settings and scan for your WI-FI router, Then enter the Wi-Fi password for your router (the same one you use for your smart phone or laptop).
You should be able to fully use your Amazon Firestick, and if you have Amazon Prime, be able to access all prime and free offerings from Amazon.
How do i get the firestick on my tv screen..set on hdm1 or hdm2 or ? I don't know how to bring it up on the screen?
The TV remote has a button for that. Input Select or Source or SEL. However simply turning off anything except the firestick should make it work. I presume the firestick came with a remote. Simply turning it off and on from that should do it. Make sure you can see the firestick when you press the buttons.
2helpful
6answers
Can you explain in simple terms that if I buy a fire stick with kodi, does that means it automatically streams various films and music from Amazon or Netflix foc. Does it needs to be jail broken
Why would you buy kodi installed FireStick when you can do it yourself in a few minutes? I mean, OK, you don't have any problem to spend some additional money in buying Kodi preinstalled Fire Stick but what if you get problems later? It is always better to know how to install Kodi on Firestick as it will help you in future too. How to Install Kodi on FireStick
1helpful
2answers
I downloaded kodi on my FireStick but it won't install it, how can i fix it
Hey, there are couple of ways to download as well as installing Kodi on Firestick. I am not sure which method you used to download Kodi. I would suggest you download Kodi using ES File Explorer and then it will show install button as soon as download completes.
You can also check this guide - https://www.firesticktricks.com/install-kodi-on-fire-stick.html
If any further issues, please let me know.
How do I get live tv with my fire stick
I have no experience of these but as they work by connecting to the internet nothing is live in the conventional sense but streamed either from a single or a series of websites the firestick is programmed to log on to. The website(s) will usually provide a mixture of "live" tv, catch up tv available for a limited time, archive material and special programming and some movies.
What you get will depend on what is available free and what needs to be paid for, your internet/wireless connection and how good you are at reading instructions and operating the remote, assuming the firestick is working correctly.
A friend had a problem with connected tv and it turned out some of the sites took a long, long time to load and he was impatient and assumed it wasn't working.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
