Question about Pioneer VSX-D510 Receiver
No sound i have just bought a new sony dvd recorder and a ps3 which i want to use through the amp . i am using both digital coaxial and optical cables (one for each) and have gone through the set up screens on the sony kit.but for some reason no sound can anyone help
  • Kuhni Dec 29, 2007
    I have exactly the same problem :-(
  • Anonymous Apr 13, 2008
    i have a 50inch pioneer hd tv built in hd receiver. just got a ps3 hooked it up to the tv via a hdmi cable and a optical cable from the ps3 to the pioneer vsx-d510 5.1channel receiver as per the instruction manual .but no sound from the rec/amp.
    reguards brian
You have the co-axial and optical inputs both set to a specific input? ie. For my xbox 360, I use optical. so I set my optical to DVD, and then I have to set the receiver to DVD to get the sound.
Posted on Jun 21, 2008
Connect ps3 just sound to surround sound
PS3 has an "optical out" port. Use an optical coaxial cable (something like this one XO Digital Optical Cable 2m 2 Metre Premium Install Series suitable for... ) to connect this to an optical in port on your surround sound receiver/amplifier.
Go into the sound settings on the PS3 and set it to output dolby digital 5.1 from the optical connection.
Switch your surround amplifier to the appropriate source.
Feb 03, 2014 | Video Game Consoles & Games
I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
Dec 21, 2009 | Pioneer VSX-D510 Receiver
Sony DG510 - Not Getting surround sound out of Cable
Did you try it on BOTH the SAT and Video 2 optical ports? Still not working? Could be the Optical cable is bad.
Does your Cable Box also have a coaxial digital ouput? It looks just like a standard RCA connector but says Digital somewhere near it. Try one conductor of a standard audio cable from it to the "DVD" coax connector. Select DVD to hear it.
If it still doesn't work jump into the Cable Box setup to make sure it's output is set up properly.
I would recommend using the coaxial digital option if you have it.
1) The cable isn't special or expensive like the optical cable is; a garden-variety RCA cable works just fine.
2) You have virtually unlimited distance to work with in the house.
3) You don't have to be so darned careful with it as with optical.
Mar 06, 2009 | Sony STR-DG510 Receiver
NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Jan 19, 2009 | Sony STR-DG510 Receiver
Sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Nov 16, 2008 | Sony STR-DB930 Receiver
I am using an HDMI cable on my STR-DG710 and get no sound
A lot of devices like PS3, HD DVD Players, Cable boxes, etc., require you to define on the setup menu if sound will be coming out of the HDMI cable or not. Most of these devices can be set to HDMI Auto, but not all of them do.
I currently have both my Blu-ray and HD DVD player outputting both video and sound through my HDMI into my STR-DG710. Both devices are setup to output sound through the HDMI.
But like the other person on here posted, it you have a DVI to HDMI cable, you won't be getting sound. The only device that will output sound from a DVI to HDMI are select computer graphics adapters like the GeForce 9800 GT series video cards, and even not all of those will have this feature.
Hope this helps.
Jun 23, 2008 | Sony STR-DG510 DTV Receiver
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Surround Sound from PS3
Are you getting any sound?
If your marantz amp is part of a home cinema system then depending how old it is will depend on if it will do it automatically.I have just bought a sony surround system and it detects the signal range ie it knows it is being transmitted in 5:1 surround.If you have an old system you may have to do this manually, this should not be diffecult there should be a sound setting.
Jan 28, 2008 | Sony Playstation 3 (PS3) Console
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
Pioneer VSX-D510 Receiver Logo
181 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
