Question about NetGear WG311T 802.11g/b (wg311tge) Wireless Adapter
Bt home hub (shuny black one) wont connect wirelessly
I have 2 old desktop machines both running Xp, they have Netgear wireless WG311 cards installed in them, but they wont connect wirelessly to the Hub,
i dont get an error message as such, all that keeps happening is when i open the netgear interface to connect it keeps jumping through the channels on the hub, it will find the right one, connect to it for about 15-20 seconds then jump through the channels again, it keeps doing to this and for the life of me i cant figure it out.
i had it connected for about an hour then it dropped and now this has happened, i have a dell laptop also, and that connected with no problems what so ever. any help much appreciated guys
Thanks
    Problem Solver:
  • 17 Answers
Maybe the wireless signel is be loose. Try removing the signal and re-insert it.
Posted on Aug 18, 2010
    Problem Solver:
  • 6 Answers
Try to disable the netgear interface and let windows manage the wifi card. This could also be happening if the signal is not strong enough where the machines are.
Is your wifi hub also a netgear? If not it may not be compatible with the cards if that is the case you will need to replace them with diffrent make of the cards preferably the same brand as hub.
Posted on Jul 27, 2009
My printer has stopped communicating with our BT home hub It was OK and the security code is correct it just cannot establish a connection. I tried it with the previous Netgear wi fi and it connects just...
you can also change the BT home hub 2.0(black)encryption type to WEP type. all you need to do is follow the steps to change the type of encryption to WEP.
  • connect a computer using the ethernet cable to the hub(its the black cable with yellow leads).
  • open an internet explorer or anyother browser, in the address bar just type 192.168.1.254.
  • you will be getting the BT home hub manager page with please reset your password, asking for three credentials.
  • in the first bar enter the default admin password or the admin password which is found in the wireless card or at the back of the home hub in the label. in the second and third bars enter the password of your own, something like admin1.
  • you will be getting another page coming with four options at the top (home, services, settings and troubleshooting).
  • click on settings, and below troubleshooting in the blue bar itself , you will see advanced settings. click on it.
  • then click on continue to advanced settings, now below home in the blue bar itself, click on wireless.
  • after you do that, you will see two options called as configuration and security. click on security. there you will see the option to change the wireless encryption to WEP.after changing the type to WEP, type the same password again in the section for password and click on apply to save changes.
  • check whether your printer is connecting to your home hub after that,
I am a person who work for BT in the tech help desk dept. if you have any trouble in doing this please reply to this message
May 19, 2010 | Kodak ESP 5 Printer
My netgear WG111t does not connect to my BT HomeHub
wths the color of the hub u have is it while or black one with the blue lights
if u forgot the passphrase at the side u ll have reset to default button will b there press for 15secs and wait for it to reboot and at the back u ll have the wireless key u can use it or the passpharase at the hub can be used, and if u want to change u can go to the routers page and u can change it manually
for further assistance pls gemme back with the error code and version of the hub if not the lights on the hub for the furhter assistance
May 22, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Usb wireless adapter for Compaq Presario 5000
Most netgear adapters will work.
They're around £20 and will connect to pretty much everything =)
They work on windows, from 98 i think. So aslong as the old tower has a sort-of up to date OS then it'll connect for you :)
Hope it helps.
Ed
Mar 17, 2009 | Compaq Presario 5000 PC Desktop
Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Feb 06, 2009 | Acer Computers & Internet
Driver Problem
I M NOT INSTALLED THE DRIVER OF NETGEAR WIRELESS WG311 ADAPTER FOR WINDOWS 2003 SERVER. PLZ. GIVE ME A DRIVER FOR WINDOWS 2003 SERVER
Jan 21, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Wireless not working from netgear wg311 to a new bt homehub2
Hi Backatya,
Check what kind of security you upgraded BThomehub 2 uses. Since the hub supports more security-types then your adapter does, I suspect an incompatibility there.
You can solve it by connecting through cable and changing security to WEP or WPA (not WPA2).
Regards Ronnie
Dec 15, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
Wireless G Desktop Card Connection to BTHome Wireless Router
uninstall the bt desk top help first then the bt wireless connection , if ur wireless card has an utility use it to configure . the connection might be due the conflict between the wireless software. checked if ur getting limited or no connectivty if so delte and recreate  the wireless profile, if ur using bt router like home hub or voyager go the router page with the ip for hub its 192.168.1.245 and navigate to advance and keep the wireless channel to 9 or 11  for voyager the its 193.168.1.1
Oct 21, 2008 | Belkin 802.11g Wireless Desktop Network...
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
Belkin N1 Wireless USB Adapter
Hi Emma,
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Please let me know how you make out.
thanks
Jan 21, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Driver for NETGEAR PCI wireless adapter wg311
You can download the driver from here..
Goodluck,
Dont forget to rate me as Fixya..
Jan 03, 2008 | NetGear WG311T 802.11g/b (wg311tge)...
NetGear WG311T 802.11g/b (wg311tge) Wireless Adapter Logo
364 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
