did you lose your key? here is a link to buy one, they are generic so you might be able to go to a local lawnmower shop for that. if it wont start with the key check your safety switches at the blade control lever under the panel and under the seat. riding lawnmowers that sit out get rusted all over, look for rust and bad connections under the service panel and battery compartment, sand connections with sandpaper..
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/136-630-331-lawnflite-lawn-tractor-1986-forest-city/electrical-without-headlights
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
SOURCE: scotts 1642 riding mower take foot off brake engine shuts off
Sounds like the safety switch in the seat is bad or disconnected. Look under seat to see if anything is unplugged.
SOURCE: my 603 lawnflite ran over a man hole cover and
Should be just behind the dash
Testimonial: "Hi thanks will check it today,i also need a workshop manual for the 603 lawnflite 30" cut,would a manual from another lawnflite model be the same?,also has anybody else heard of the lawnflite 603 model or others, sucking manhole covers into its cutter deck,beware all lawnflite owners,this has happened to me on its second cut from new,i have cut our lawn with a westwood tractor for the last 26 years,and never had any trouble with manhole covers!!!!!!!!"
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
