Question about HP LaserJet 4250n Printer
Hp 4250 tn when i try to print get an error 13.05.00 papper never makes it though the fuser
    President:
  • 2,049 Answers
Error message means "Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken."
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Try cleaning your feed rollers...
There are two types of rollers in printers: hard plastic and rubber. Plastic rollers can be cleaned with alcohol (isopropyl). Rubber rollers can be cleaned with a rubber roller cleaner and restorer like the one in the link (you can find other brands, but make sure its for rubber).
http://www.lmcomp.com/80008.html
Posted on Jul 27, 2009
Error 50.1 hp 4250 printer
This is a fuser error, it could be a faulty thermal sensor on the fuser but can also be caused by a faulty power supply.
This model commonly has dry joints in the power supply which can be fixed depending on your level of skill.
Mar 02, 2012 | Office Equipment & Supplies
Hp 4250 laster jet toner not adhering when printing envelopes. Seems fine for 8 1/2 x 11 paper. Only happens with envelopes
Try this:
Check the printer configuration pannel in your computer.
Select papper size(envelopes) and change the weight.
Jun 27, 2011 | Office Equipment & Supplies
Hp printer 4250 is error 50.0
Fuser Error, Replace the Fuser (Part Number RM1-1082) In the rear behind the door very easy to do.
Dec 29, 2010 | HEWLETT-PACKARD Hewlett Packard 21A - HP...
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
WHERE'S THE FUSER ROLLER AND WHERE DO YOU PURCHASE FUSER OIL ON A HP LASER JET 4250 N PRINTER?
The 4250 uses an "assembly" that does not use fuser oil. The fuser is housed in the rear of the printer. It applies heat and pressure to the paper as it exits, melting the toner into the fibers of the paper. Some fusers are remanufactured. If done properly, with the proper amount of fuser sleeve grease, these fusers can last as long as the original equipment fuser.
If not properly trained, fusers should not be disassembled and rebuilt.
Oct 01, 2009 | HP LaserJet 4250n Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Jan 09, 2008 | HP 4250 Monochrome LaserJet Printer
Hp 4250 GHOSTING
Are you telling the machine that paper type is letter head or envelopes, It must be done, it changes temp of fuser to suit the paper type, no it is not a power supply problem change paper type to card stock/thick/letterhead etc to suit then machine will adjust temp to suit.. ie file, print properties paper type.
50.2 fuser error replace fuser.
Dec 06, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
718 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
