Question about Metra Chevy Truck 88 94
There is power going to the horn but no connection at the steering wheel
  • dchevalier Jul 27, 2009
    yes. i was told the whole assembly was called a clock spring, when i tried to locate the part i was told they didn't know what it was.
  • yadayada
    yadayada May 11, 2010
    year and model? does it have a steering wheel airbag?
    Top Expert:
  • Metra Master
  • 79,851 Answers
You need the flexible rotating contact that goes under the steering wheel, this is a dealer only item, the dealers and tech's call it a clock spring, remember it is the steering wheel airbag contact, u must disarm the airbag to replace this part, if you don't you can break your fricking neck if it goes off.
Posted on Jul 27, 2009
Horn does not sound on the ring, aux power outlet and cig lighter outlet , all three do not work, but all fuses good
Some fuses look good..testum w light. Ythe wiring cud be bad .clockspring on steerin wheel may b worn
Nov 17, 2017 | Cars & Trucks
I just wired a new horn on my 97 Nissan and it won't work. I had wired the same horn weeks prior and it only worked for a week. The relay and fuse are good. Should I check the sterring wheel?
Make sure all your connections are good. If the horn relay clicks when you push the horn, you're getting power to it but you might not be getting power out. Get a test light and make sure you have juice at the relay going to the horn and at the horn connections.
Feb 15, 2017 | Nissan Cars & Trucks
Horn on a 2010 silverado will not work either from the steering wheel or key fob
You have all the informations to find your problem. jump a wire on connector X4 G1 tan wire to ground and check X1 E5 with a test light or multimeter to see if there is a output, you should have 12 volts. If you dont have any voltage the horn relay is defective. I check in the shop manual and the relay come with the underhood fuse block.
Apr 02, 2015 | 2010 Chevrolet Silverado 1500
Horn only works when steerin wheel is turned to the right
This problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to disarm the airbag system can result in an unexpected Airbag deployment and possible serious personnel injury disconnect the battery 30 minutes prior to start of work.
Sep 10, 2010 | Toyota Pickup Cars & Trucks
Removing steering wheel from 1986 model ford xlt spectron van automatic
first off the center cover needs to be removed from the steerin wheel. some can be pulled off and some have screws on the back side you remove then the cover will come off. once you determine that be careful the covers have control wires that are attached to it that go into the column. gently push in on the connector and turn counter clock wise and the wire will come out with the cover.you can usually rent a steerin whell puller from your local parts store and and use it to remove the steerin wheel after you have removed the nut holdin the steerin wheel on. if you dont have the puller, you can back the nut off to where its flush with the steerin shaft, then turn counter clock wise approximately another quarter turn and take a hammer and strike the nut and this usually breaks the steering wheel lose from the shaft. let me know.
Feb 11, 2010 | 1987 Ford Ranger
The horn will not sound
You will need to check the fuse to the horn that should be located under the steering wheel or near the floorboard.
Dec 10, 2009 | 2003 Chevrolet Cavalier
Steerin wheel is hard of my ford tempo car . i
Hi:
If you have power steering, first check to see if you have fluid in the power steering reservoir. If you don't have power steering, you most likely have binding in the rack and pinion unit, and that has to be replaced as an assembly, and is a bit pricey, so check your fluid first.
If the fluid is full the power steering pump could be bad, but usually they growl, and are noticeable.
Oct 26, 2009 | 1991 Ford Tempo 4 Door
Horn does not work fus not blowd
check for connections and power at horn with someone helping u if power, horn bad if no power recheck fuse and horn switch
Oct 25, 2009 | 2006 Volkswagen New Beetle
Metra Chevy Truck 88 94  Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
