Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
I have a minn kota 42pd/c. boat shop installed inline fuse between new 27 series battery and socket where we plug the TM in at front of boat. we blew 10amp fuse, then a 25amp fuse right away and eventually a 30amp fuse blew which is max that fits. is it even necessary to have the inline fuse if the TM is the only thing connected to the battery? i've never heard of having this sort of setup. is it ok to just eliminate the fuse and have the battery direct wired to the plug receptacle? if not, then how big of a fuse or circuit breaker is needed for that motor?
  • 86 Answers
It is needed. I usually install 3 amp fuses. It sounds like you have a short somewhere. I would trace the wiring and make sure it did not get the sheath cut and is possibly contacting the boat. I always install a fuse and that eliminates the threat of a fire. There is a reason that the fuse is blowing and if you remove it then you move the problem straight to the battery and you will most likely see smoke. Also if you dont install the fuse the equipment factory warranty will be void. You really just need to check out the wiring carefully. If there is no problem with the wiring then there is a problem with the unit and should be exchanged.
Posted on Aug 02, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Plug at front of boat for trolling motor not working??
    Check for a blown fuse and check plug with a volt meter just to be sure its not the trolling motor itself.
    May 17, 2010 | Minn Kota 65 AutoPilot Motor/Sonar Combo...
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Bad control board
    If the voltage on your boat's plug drops down to .8v, then the problem is almost certainly in the boat. Trace the wires. You probably have a corroded wire connection somewhere. If there is a fuse in the circuit, check it and it's holder very closely.
    Jun 13, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota 54lb hooked up backwards (Pos. to Neg) wont work
    Unfortunately, those units have a circut board at the power source and if there is no fuse you more than likely destroyed that board. Take the casing apart (the part attached to the boat) it should be two halves. That inital board you see is probably what is destroyed. Of course before i did that I would look for an inline fuse near where the cables attach to the battery or under the unit in the nose of the boat. There is nearly always a fuse if it came from the factory or dealership with the unit so i'd play a little extra hide and go seek for that before doing anything else.
    Best of Luck
    Jun 02, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Hook up for one battery operation for minn kota trolling motor
    I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Removing Prop
    There should be a retainer nut accessible at the rear of the prop (in the center of the prop. Remove this and the prop should slide off.
    Mar 13, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
    269 people viewed this question
    Top Minn Kota Boating Experts
    Colin Stickland
    Colin Stickland
    Andrew Taylor
    Andrew Taylor
    Phil Walker
    Phil Walker
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
