How to input simulations code for AR-5516 - Office Equipment & Supplies
  • Steven_L Aug 08, 2009
    Thanks you.
  • 134 Answers
If this is a sharp product press c*p*
Posted on Aug 05, 2009
Simulation for AR sharp 5516
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
or
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Feb 01, 2016 | Sharp Office Equipment & Supplies
Have Sharp - AR-5516 and H5 error blinking on the screen
Main code 14 Start key Sub code 0 Start key
OR
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Mar 28, 2015 | Sharp Office Equipment & Supplies
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
H2 problem sharp AR 5516
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
89 people viewed this question
jasbo
jasbo
