Question about Car Audio & Video
Battery was disconnected, now no power to radio,cd, etc. code is 3.8 405 but buttons on unit only 1-6 with 7-12 when holding down button. All fuses O.K. and been replaced in case. Radio/cd is from 2002, in a 1979 Mercedes 450sl, I have manuals but no idea of solution-it all worked before work was done ,no comeback with tech, he's history. Also on manual is that dot between the 3.8 what's that about. No decimal pts. on unit. Help, please.
  • 51 Answers
If it has an anty theft system, (which it might not because it is an old car) then it will need to be reset, search in the manuls for something that says resetting radio or something similar and follow directions. If that dosent work, then please dont hate me
Posted on Jul 27, 2009
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Where is the button on the radio to turn on the cd player which is in the trunk
Let's see, the 98 still had a cassette player in the head unit correct?
There should be a button toward the top, far right, that says Tape/CD.
If the CD player has been disconnected, it may be necessary to 'reboot' the system to get the head unit to sync up with the CD player. Disconnecting the battery is the simplest way, but you will have to reset the anti-theft code in the radio and reprogram various memories (seats, etc) if you disconnect the battery.
Mar 06, 2011 | 1998 BMW 7 Series
I cant insert a cd into my 6 disc cd player
hold the power button down for 60 seconds or pull the fuse to the radio to reset the cd player
Sep 11, 2010 | 2004 Dodge Durango
How do i make the radio in my 1993 VW cabriolet work the guy i bought it from said you have to input a code but he couldnt remember what steps to take. i do have the code he wrote that down. what do i do
You can try this. It's for a Passat but it's most likely the same for all models that year.
1. Turn the radio on. "SAFe" should appear on the display.
2. Push the AM/FM and SCAN buttons. Hold them until the display changes to 1000, then release. If the buttons are held too long or accidently pushed again this will be interpreted as entry of an incorrct code.
3. Enter the code usung the first four station programing buttos. The code will appear on the display.
4. Push the AM/FM and SCAN buttons and hold until the display changes to SAFe. Release the buttons.
After 2 incorrect tries the radio will lock up and refuse any more tries. Leave the radio on for at least 1 hour and then you can try again. Same deal, 2 tries and then lock up. The radio does not lock up permanently.
This needs to be done any time you disconnect power so write it down somewhere and keep it. Any time you disconnect the battery or disrupt power to the radio, blow a fuse or remove the fuse it will have to be done.
Hope this helps.
Apr 11, 2010 | 1993 Volkswagen Cabriolet
My 2004 odyssey's radio is locked. the code
check fuse box for blown fuse then remove or have removed the radio and retrieve the radio serial number off the back, then go to your local honda dealer and they should bee able to help you
Mar 01, 2010 | 2004 Honda Odyssey
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
Radio and CD scanning
try holding down the scan button. if this doesnt work, make sure you have the radio code ( if its security protected ), disconnect your battery for 30 mins, this should reset the unit.....i hope this was helpfull
Sep 16, 2009 | 2000 Porsche Boxster
03 vibe cd player will not respond
I blew a fuse controlling the radio, charging system, turn signals, heater fan, ,etc..this ran down my battery.
When I replaced the fuse, the CD player would not respond, but the radio worked.
I disconnected the battery for over 30 seconds, hooked it back up, and the time reset on the radio to 12:00 and the CD player works again.
Jan 23, 2009 | 2003 Pontiac Vibe
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
Car Audio & Video Logo
150 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
