Question about Garden
Need replacement part impossible to track down!!!
Need to get a replacement pullstart has anyone any ideas
  • 1 more comment
  • lookout_mend Aug 17, 2009
    hey longhorn, it's a JCB cs38 i've googled and been in touch with jcb who don't even know they make the product, would appreciate any help cheers.
  • Gene Tuck May 11, 2010
    Does this chainsaw have a Brand and a model number?
  • Dwain Pippen May 11, 2010
    For WHAT saw? Make and model.
I am looking for pullstart for Tivoli 60 hedge trimmer
Fixya does not sell replacement pullstarts.
Oct 27, 2016 | Garden
How do you fix a pull start
-Take the handle off the rope. You want to only have one knot in one end of the rope. (Of course, if the rope's already broken, you can skip this step ....)
-Get the reel and lay it facedown.
-Get the coil, and begin carefully winding it up so that it fits inside the grooved edge on the reel. BE PATIENT - this will take time.
-On the inside of the coil, there should be a little hook on the end of the coil. That hook matches one inside the pullstart cover when you put the two pieces together. The trick is to get the hook on the reel to catch the hook on the pullstart cover. CAREFULLY put the reel and coil inside the cover, and ***** the bolt in for a moment to hold it in place.
-Turn the pullstart reel clockwise until you feel the hooks catch each other. Feel some resistance? Good, that's what you want.
-Take the bolt back out, and reassemble the starter pawl assembly inside the pullstart, then put the bolt back in and tighten it.
You should now have a complete assembly, minus the pull rope. -Now, looking down into the pullstart, notice there is a hole in the reel off to one side. This is where your rope threads through. Grab the reel, and crank it around about .... four or five times, and try to get the hole in the reel lined up as close as possible with the outer hole in the pullstart cover. -Take your rope (you DID take the handle off first, right? Oh yeah, it broke off ...), and thread it through the reel, then through the outer hole in the cover. This will be a little tricky, as you need to be holding the reel so it doesn't unwind ...
-SLOWLY let the reel start to retract, but don't let it go all the way. Does it look like it's drawing the rope all the way back in? If so, great! If not, pull the rope back out, crank the reel around another turn, and try again.
-Once you have the reel set to where it will retract the rope all the way, thread on your handle and tie it off. You're done!
Apr 16, 2016 | Motorcycles
Behringer mx2442a
Bad power supply cap...
Jun 07, 2017 | Music
How do I replace the starter pull rope on TB70SS?
You must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
Pullstart jamed removed putstart rope no problem
If after removing the starter the starter pulls easily but you can not turn the flywheel the engine is probably seized. Could be a piston failure or a bearing failure. check to be sure nothing is caught under the flywheel binding it up.
Jan 14, 2010 | Echo Garden
How do i fix the pullstart, including attaching to inner coil
You can remove the cover and you will then be able to view the pulley and crank as well. You can pry up tabs on pullstart, rewind and replace.
Sep 23, 2009 | Poulan Featherlite Gas Blower, with Low...
2004 vw beetle convertible - the inside of the convertible top near the back window has a "casement" along the edge of the fabric top that seems to attach or slide into a track near the window. mine has...
That happened to me. I tried to re-insert the window into the track but it was impossible. The dealer ordered some clips and I think I paid about $50 to have it fixed.
Jun 17, 2009 | 2004 Volkswagen New Beetle Convertible
Replacing rear passenger window
I ended up removing the regulator, replacing the window in its track and ordering a replacement regulator.
the information provided by FixYa was helpful in getting the window back in place but the main issue was 'restringing the cables' on the regulator - apparently difficult if not impossible to do, therefore the necessity to order the new part.
Mar 21, 2009 | 2004 Pontiac Grand Prix
Tracking control
Sounds like the remote control isn't working.  Getting support for Durabrand portable DVD players is impossible.  The company that manufactured them for Wal Mart went out of business last November.  I've heard that Wal Mart is replacing them with a unit of equal or lesser value.
There's a blog on Rip Off Report.com about it.
Aug 18, 2008 | Durabrand PDV-705 Portable DVD Player
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
